10-04-2012, 08:33 | #1 (permalink) |
Banned Join Date: Dec 2008
Member: 916579 Status: Offline Sonork: 7280072 Thanks Meter: 23 | wht is prob z3x team plz help me... samsung model s-5570 software flashing showing this msg........ Count supported models - 319 File analysis... OK Searching USB Flash Interface... detected COM29 Setup connection... OK Sending mibib... Error Done with Samsung Tool ver 12.7 plz help wht is this? |
10-04-2012, 08:38 | #2 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | probably wrong name for pit file... what is the name of the file you use ? [edit] try to rename this way : TASS_v1.0.ops |
10-04-2012, 09:29 | #3 (permalink) |
Member: 916579 Status: Offline Sonork: 7280072 Thanks Meter: 23 | i already many tries...my file name is....TASS v1.0.ops but still same prob....and i changed other firmware version...not solve my prob...i getting changed the folder..now showing this msg... Download Start... <0> Create File... <1> StartThread Detected : 1 <2> StartThread Detected : 0 <3> StartThread Detected : 0 <4> StartThread Detected : 0 <5> StartThread Detected : 0 <6> StartThread Detected : 0 <7> StartThread Detected : 0 <8> StartThread Detected : 0 <1> setup connection... |
10-04-2012, 09:40 | #4 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | In odin when dl can't start even if your ops file is good it is because name of it is wrong. did you put the underscore between TASS and v1.0, exactly as written above ? Whatever flashfile you use, ops file is the same for your phone. Just be sure it's nammed the correct way. |
10-04-2012, 09:40 | #5 (permalink) |
Member: 916579 Status: Offline Sonork: 7280072 Thanks Meter: 23 | now this msg with odin.. Download Start... <0> Create File... <1> StartThread Detected : 1 <2> StartThread Detected : 0 <3> StartThread Detected : 0 <4> StartThread Detected : 0 <5> StartThread Detected : 0 <6> StartThread Detected : 0 <7> StartThread Detected : 0 <8> StartThread Detected : 0 <1> setup connection... <1> odin mode.. check plcatform verification. <1> VerifyPlatform:V0, P0,R0 <1> START!!! <1> set download environment. <1> big partition size!! <1> big partition size!! <1> big partition size!! <1> big partition size!! <1> big partition size!! <1> mibib download.. |
10-04-2012, 09:46 | #8 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | How To Update Samsung S5570 Galaxy Mini Firmware But I just asked you to rename your ops file to give it a shot. One more time : when odin stucks at mibib, it is because the file has not the right name. It may be good, but without the right name odin won't use it. |
10-04-2012, 09:49 | #9 (permalink) |
Member: 916579 Status: Offline Sonork: 7280072 Thanks Meter: 23 | yeh i changed the file name again flashing with odin...but still same error now file name is TASS.ops firmware version...S5570XWKE3_S5570ERAKE3_S5570XXKB2 Download Start... <0> Create File... <1> StartThread Detected : 1 <2> StartThread Detected : 0 <3> StartThread Detected : 0 <4> StartThread Detected : 0 <5> StartThread Detected : 0 <6> StartThread Detected : 0 <7> StartThread Detected : 0 <8> StartThread Detected : 0 <1> setup connection... |
10-04-2012, 11:19 | #10 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Last trick : repeat full procedure at each try : Unplug phone, release and put back battery, close odin, put phone in dl mode, connect phone, launch odin, select files. I had several problems when I just unplug and replug phone between two tries. |
10-04-2012, 12:15 | #11 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
2.1 In tread body use full description of problem not waste our and your time while we will ask this: - phone models, - status of phone before any job with phone, - phone firmware, - cable which you use, - if possible - screenshots or full, not cutted log of each jobs. what flash inside phone, what flash you try flash. may be boot not compatible. | |
10-04-2012, 18:12 | #14 (permalink) |
Member: 916579 Status: Offline Sonork: 7280072 Thanks Meter: 23 | i getting a simple work... 1-remove battery from mobile and system shutdown...when i come back after 3 hours.. Again Pc On... inset Battery in mobile...going to download mode in mobile...inset usb cable and 2 file select.. 1-Odin_Multi_Downloader_v4.42 2-TASS.ops 3-S5570JPKT2_OJPKT2_EGY_Android_2.3.6 Flash after processing..my phone is ok....simple...no other method.... |
08-11-2013, 18:46 | #15 (permalink) |
Registered User Join Date: Mar 2006 Location: tuljapur
Member: 246286 Status: Offline Thanks Meter: 14 | samsung model s-5570 software flashing showing this msg... Download Start... <0> Create File... <1> StartThread Detected : 1 <2> StartThread Detected : 0 <3> StartThread Detected : 0 <4> StartThread Detected : 0 <5> StartThread Detected : 0 <6> StartThread Detected : 0 <7> StartThread Detected : 0 <8> StartThread Detected : 0 <1> --- cannot open the usb serial port. code: 5 |
