02-07-2015, 15:52 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Samsung I9300, Sending sboot.bin... Error Before Flash, In This Set Network Full Show But Can't Connect Call & Show Emergency. That's Why I Wanted To Flash This Set. I Was Trying By Factory Firmware With Odin. Code: <ID:0/030> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> CODE_I9300XXBLFB_782020_REV00_user_low_ship.tar.md5 is valid. <OSM> MODEM_I9300DDLF3_REV02_REV04_CL1162986.tar.md5 is valid. <OSM> CSC_ODD_I9300ODDBLF3_CL758737_REV00_user_low_ship.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/030> Odin v.3 engine (ID:30).. <ID:0/030> File analysis.. <ID:0/030> SetupConnection.. <ID:0/030> Initialzation.. <ID:0/030> Set PIT file.. <ID:0/030> DO NOT TURN OFF TARGET!! <ID:0/030> Get PIT for mapping.. <ID:0/030> Firmware update start.. <ID:0/030> sboot.bin <ID:0/030> NAND Write Start!! <ID:0/030> <ID:0/030> Complete(Write) operation failed. <ID:0/030> Added!! <OSM> All threads completed. (succeed 0 / failed 1) Then I Try With Z3X & It's Show This Error. Log. Code: Selected model: I9300 Selected port: Selected port speed: 115200 File analysis... OK Total file size: 0x4BEEE90C Searching USB Flash Interface... detected COM30 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9300_7-2-2015_19-57-55.pit Sending sboot.bin... Error Done with Samsung Tool v.18.8 Now Handset In This Condition. firmware upgrade encountered an issue please select recovery mode in kies and try again In Download Mode. ODIN MODE PRODUCT NAME: GT-I9300 CUSTOM BINARY DOWNLOAD: YES (3 counts) CURRENT BINARY: Custom SYSTEM STATUS: Custom What Should I Do Now ?. Thank You In Advance. |
The Following User Says Thank You to MyGSM World For This Useful Post: |
02-07-2015, 16:49 | #4 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friends, My Handset Have Like This Problem. http://forum.gsmhosting.com/vbb/10088050-post1.html |
02-07-2015, 18:47 | #9 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, I Really Appreciate Your Help. Now Handset Is In Working Condition But Main Problem Is Not Solve Yet. It's Show "Emergency Calls Only" & When I Call It's Show "Not Registered On Network" Still Searching Solution For It... |
02-07-2015, 19:54 | #10 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Code: Selected model: I9300 Selected port: COM50 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM111 Reading phone info... Software version: I9300XWUGML4/I9300DDUGMK1/I9300ODDGML4 IMEI: 35206XXXXXXXXXX Done with Samsung Tool v.18.8 Code: Selected model: I9300 Selected port: COM50 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x59D4F3F4 Searching USB Flash Interface... detected COM30 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9300_8-2-2015_0-16-8.pit Sending sboot.bin... OK Sending tz.img... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending modem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:05:42) Done with Samsung Tool v.18.8 Is It Possible To Downgrade ? |
02-08-2015, 13:50 | #11 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: PAKISTAN Age: 34
Member: 1082907 Status: Offline Sonork: 100.1606954 Thanks Meter: 342 | Quote:
2nd repair network with z3x via repair option only network repair | |
02-08-2015, 13:58 | #12 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
nothing to discuss more. i htink 1000+ thread exist regarding this. | |
