06-19-2017, 14:57 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: .:INDIAN:.
Member: 75838 Status: Offline Thanks Meter: 67 | Sm-g531f flashing error FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G531F Software version: 28.2 File analysis... Ok Total file size: 0x63682480 (1590 Mb) Searching USB Flash interface... COM3 detected Setup connection... Ok Reading PIT from phone... Ok Sending Sboot.bin... Ok Sending Recovery_Sboot.bin... Ok Sending Loke_Recovery.bin... Ok Sending Loke_Primary.bin... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img... error Done with Samsung Tool PRO v.28.2 |
The Following User Says Thank You to sunil kumar For This Useful Post: |
