Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Direct Codes ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
06-19-2017, 11:03 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | wifi problem help me Use [Enter Flash] or Switch Off Device and Insert Cable Samsung SM-T815 (Tab S2 9.7 LTE) at USB (COM6) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-T815_Read.pit File: T815XXU2BPG3_T815OJV2BPG1_T815XXU2BPG2_HOME.tar.md 5 Partition: BOOTLOADER, Image: sboot.bin, Size: 0x001CEB10 (1.81 MB) Partition: BOOT, Image: boot.img, Size: 0x009D9120 (9.85 MB) Partition: RECOVERY, Image: recovery.img, Size: 0x00AE3120 (10.89 MB) Partition: SYSTEM, Image: system.img, Size: 0xA4CEE4B0 (2.58 GB) Partition: RADIO, Image: modem.bin, Size: 0x02104430 (33.02 MB) Partition: CACHE, Image: cache.img, Size: 0x064CF120 (100.81 MB) Partition: HIDDEN, Image: hidden.img, Size: 0x01129270 (17.16 MB) Flash Write Done: 03:28.527 Restart Done |
06-19-2017, 15:22 | #2 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-T815 Software version: 28.2 File analysis... Ok Total file size: 0xCA760696 (3239 Mb) Searching USB Flash interface... COM23 detected Setup connection... Ok Set PIT file... Ok Reading PIT from phone... Ok Sending sboot.bin... Ok Sending param.bin... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img... Ok Sending userdata.img... Ok Sending modem.bin... Ok Sending cache.img... Ok Sending hidden.img... Ok Flashing done (time - 00:03:51) Done with Samsung Tool PRO v.28.2 |
Thread Tools | |
Display Modes | |
