12-01-2016, 16:46 | #1 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2598620 Status: Offline Thanks Meter: 35 | [WORLD FIRST] SM-A510F IMEI Repair Done By Z3X [FONT="Arial Black"]Hi to all first of all sorry for my bad English.... After apologize let's begin... 1) First download ODIN3 V3.10.7 from HERE ONLY USE THIS ODIN NO Z3X NO OTHER FLASH TOOLS !!! IT MIGHT BE WON'T WORK ON WINDOWS XP 2) Next download TWRP Recovery from HERE ( ALL CREDITS GOES TO XDA ) THERE IS DIFFERENT FILES FOR MARSHMALLOW AND LOLLIPOP 3) Now download SuperSU v2.76 HERE ( ALL CREDITS GOES TO CHAINFIRE ) 4) After all downloads copy SuperSU file to SD Card or Device's Storage GO TO SETTINGS > DEV OPTIONS > ENBALE OEM UNLOCK & USB DEBUGGING 5) Open ODIN and open OPTIONS tab and close AUTO REBOOT and select TWRP on AP tab and start flashing 6) After flashing ends press VOL DOWN + POWER + HOME when screen offs (Keep pressing HOME + POWER) imidiatelly release VOL DOWN and press [COLOR="reiINSTA UP [/COLOR] 7) Now you must entered TWRP Recovery click INSTALL and select SuperSU file 8) When installed finished reboot your device DEVICE CAN REBOOT 1-2 TIMES BE PATIENT 9) You should sucessfully ROOTed u'r device 10) Open Z3X PRO Tool select model A510F and jump REPAIR tab 11) Write IMEIs to areas and select device on device tab 12) Click REPAIR button and give ADB and ROOT access, 13) After REPAIR ends and device REBOOT itselfs [COLOR= "red"]re-select device[/COLOR] on device tab and click PATCH CERTIFICATE button wait for operation ends14) Now plug a SIM Card and check signal status ALL CREDITS GOES TO ME, XDA MEMBERS, ODINDOWNLOADER.COM AND CHAINFIRE IF I'M HELPED TO YOU JUST PRESS THANKS BUTTON GOOD LUCK TO EVERYONE |
The Following 21 Users Say Thank You to LastRevolution For This Useful Post: |
12-03-2016, 22:39 | #2 (permalink) |
Freak Poster Join Date: Aug 2007 Age: 44
Member: 573393 Status: Offline Thanks Meter: 11 | Repair not Done helpe Waiting ADB device... Ok Reading phone info... Model: SM-A510F Android version: 6.0.1 Product code: Phone version: PDA version: A510FXXU3BPJ8 CSC version: A510FDOJP3BPJ1 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: R58H9043BEY Chip name: EXYNOS7580 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Exception: Format 'error (%s)' invalid or incompatible with argument Done with Samsung Tool PRO v.27.3 |
12-04-2016, 06:14 | #3 (permalink) | |
No Life Poster Join Date: Feb 2010
Member: 1228709 Status: Offline Thanks Meter: 268 | Quote:
Code: Phone version: | |
12-05-2016, 06:11 | #4 (permalink) | |
Member: 2598620 Status: Offline Thanks Meter: 35 | Quote:
İf your device is Android 6 don't try to flash my link if its not try 4files firmware right here or z3x support | |
12-17-2016, 16:03 | #5 (permalink) |
Junior Member Join Date: Jan 2006 Location: AFRICA
Member: 221532 Status: Offline Thanks Meter: 1 | Waiting ADB device... Ok Reading phone info... Model: SM-A510F Android version: 6.0.1 Product code: SM-A510FZKDCAC Phone version: A510FXXU3BPK4 PDA version: A510FXXU3BPK4 CSC version: A510FOXY3BPK4 CSC country code: Central Asia CSC sales code: CAC HW version: MP 0.200 Phone SN: R58HB0K0PDN Chip name: EXYNOS7580 Modem board: SHANNON310 RF cal date: 20161103 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... error (error(5)) Done with Samsung Tool PRO v.27.5 |
12-17-2016, 18:52 | #6 (permalink) | |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Quote:
anyway what firmware phone had installed Lolipop or MM | |
02-09-2017, 15:53 | #12 (permalink) |
Junior Member Join Date: Jan 2008
Member: 692954 Status: Offline Thanks Meter: 3 | Waiting ADB device... Ok Reading phone info... Model: SM-A510F Android version: 6.0.1 Product code: SM2A510FZKAITV Phone version: A510FXXU3BQA3 PDA version: A510FXXU3BQA3 CSC version: A510FOXA3BQA3 CSC country code: ITALY CSC sales code: ITV HW version: MP 0.200 Phone SN: R58H32H2SFJ Chip name: EXYNOS7580 Modem board: SHANNON310 RF cal date: 20160318 IMEI: Checking Super user right... false Root your phone manually and then repeat Done with Samsung Tool PRO v.27.7 |
02-09-2017, 16:01 | #13 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | Quote:
check the first post.. b.r. | |
The Following User Says Thank You to bk.gsm For This Useful Post: |
12-30-2017, 12:33 | #14 (permalink) | |
Insane Poster Join Date: May 2012 Location: RSA
Member: 1760959 Status: Offline Sonork: 100.1681137 Thanks Meter: 9 | Quote:
thanks sooooooo much boss its really work for me | |
The Following User Says Thank You to mustaq14 For This Useful Post: |
03-08-2018, 20:25 | #15 (permalink) |
Insane Poster Join Date: Nov 2010 Location: ******
Member: 1456151 Status: Offline Thanks Meter: 8 | THANKS ALL DONE REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 8. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-A510F Software version: 30.8 Waiting ADB device... OK Reading phone info... Model: SM-A510F Android version: 6.0.1 Product code: Phone version: PDA version: A510FXXU4BQD1 CSC version: A510FVFG4BQD1 CSC country code: Germany CSC sales code: VD2 HW version: Phone SN: R58H80RNADW Chip name: EXYNOS7580 Modem board: Security patch: 2017-04-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.30.8 BR |
