11-22-2017, 09:45 | #1 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1375596 Status: Offline Thanks Meter: 1 | Write cert problem J710F Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM2J710FZKNXSG Phone version: J710FXXU3AQD3 PDA version: J710FXXU3AQD1 CSC version: J710FOJV3AQD1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.300 Phone SN: RF8J2xxxxx Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-04-01 RF cal date: 20170224 IMEI: 35523xxxxxxx Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: E6 07 00 00 00 00 00 00 00 00 00 00 FA C1 83 29 Calculating... OK Initialization AT RIL... AT RIL stopped, restarting... OK Checking for compatible phone and cert Phone KEY ID: 0740 Checking certificate file... error Incorrect IMEI signature Done with Samsung Tool PRO v.29.8 i have problem with write cert... *I have try many cert and no result...please help |
11-22-2017, 14:29 | #3 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
The Following User Says Thank You to amleto90 For This Useful Post: |
11-22-2017, 21:20 | #4 (permalink) | |
Member: 1375596 Status: Offline Thanks Meter: 1 | Quote:
I have no original cert because the cell phone was corrupted when I do patch certificates I must first root my cell phone ... after that, my Google account is blocked by custom recovery please help | |
11-22-2017, 21:53 | #5 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Hello to bypass frp google account use COMBINATION files compatible with the firmware you installed on the phone do this install the file combination via odin go to factory mode select developer option and activate oem to disable frp then flash 4 part of the original stock firmware , done the flash of firmware you can proceed with the root and imei repair and patch cert |
11-22-2017, 22:14 | #6 (permalink) | |
COMBINATION_OXA_FA60_J710FXXU3AQD1_OXAFAC_CL756498 7_QB13210711_REV03_user_mid_noship.tar.rar https://www.androidfilehost.com/?fid=673368273298973853 | |
