07-23-2015, 16:24 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Write CERT SM-N910T Done with Samsung Tool PRO v.21.8 Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Choose diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-N910T Selected port: COM142 SAMSUNG Mobile USB Serial Port Software version: 21.8 Checking certificate file... OK KEY ID: 0772 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-N910T Android version: 4.4.4 Product code: SM-N910TZKETMB Phone version: N910TUVU1ANK4 PDA version: N910TUVU1ANK4 CSC version: N910TTMB1ANK4 CSC country code: USA CSC sales code: TMB HW version: REV1.1 Phone S/N: RF8FA061ELP Modem board: MDM9225M RF cal date: 2014.10.07 IMEI: 356095060256252 Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0772 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.21.8 |
