08-11-2016, 13:32 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | WRITE J500FN cert failed BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500FN Selected port: COM30 SAMSUNG Mobile USB Serial Port Software version: 26.3.1 Checking certificate file... OK KEY ID: 0151 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J500FN Android version: 5.1.1 Product code: SM-J500FZDAXEF Phone version: J500FNXXU1AOI1 PDA version: J500FNXXU1AOI1 CSC version: J500FNOXX1AOI1 CSC country code: France CSC sales code: XEF HW version: MP 0.400 Phone S/N: RV8H20QJ4XJ Modem board: MSM8916 RF cal date: 2016.02.19 IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.26.3.1 |
08-11-2016, 15:03 | #3 (permalink) |
Freak Poster Join Date: Feb 2010 Location: karachi pakistan
Member: 1237819 Status: Offline Sonork: [email protected] Thanks Meter: 148 | i nedd j500f ok tested crt file |
