11-07-2013, 17:20 | #166 (permalink) | |
Junior Member Join Date: Dec 2010
Member: 1468990 Status: Offline Thanks Meter: 11 | Quote:
Yes sure,i always repair all: IMEI,PRODUCT CODE,SERIAL In which case are you?IMEI correct and serial 00000? If yes,use the method I told you download SRS samsung unlock tool from here,install and use guide: srs-samsung-unlock-Install Now repair your imei and remember that if you are repairing an i9300 use i9100 option to repair imei. When imei and product code are good (remember to select only repair efs,imei and product code,no serial here) and use COM option and not USB in repair option. MAke the rebooting process completed (when is at 80-90% phone is already rebooted so you can connect now uart) connect it and make process completed. Now use the other software to change serial (see my old post) and remember to add imei and serial both. Now your phone have a good serial ,imei and product code too SOmetimes is needed to change another time imei with same procedure using i9100 option IF you see other threads you see other people have made complete repair WHEN YOU REPLACE EMMC OR YOU ARE IN THE CASE THAT HAVE IMEI NULL AND SERIAL 0000 BEFORE TRY TO REPAIR flash in odin mode and select PDA option this file that is an efs repair WHEn you flash it your efs now is semi-good because you have to change serial,imei and product code but now it's not iMEI NULL flash file is here: I9300_Repair_efs.tar IF you want more details ask (however remember with some version of firmware z3x doesn't work well and if you are in the case of it's not found your uart cable it's for that!!) SO my advise ,when you are in the case of IMEI NULL and no screen in *#9090# make a downgrade on one of the first versione of 4.1.2 and start from here (better to make a full wipe) There are many technics to REPAIR EFS and restore this partion (techniclly the problem are only in nv_data file ) without z3x box too but with this is easyer,even if some incompatibilities sometimes can cause problems | |
The Following 2 Users Say Thank You to freshh For This Useful Post: |
11-07-2013, 21:13 | #167 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Switzerland Age: 48
Member: 1873863 Status: Offline Thanks Meter: 67 | Thank you freshh for your very useful answer !! We waited very long time for a great detailed message like your !! You are really a great guy , respect !! I am one of the many chicken that bought z3X because everyone here say is the best, but it fail in the most important feature, serial correction !! Best for what ? i have some ideas but can't write here or i risk to be banned... i am very disappointed by z3x team. |
11-08-2013, 09:19 | #168 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Wikon, Switzerland
Member: 1012778 Status: Offline Thanks Meter: 245 | @freshh: thank you very very much for your help! I have the correct IMEI and SN back now ...but it doesn't connect to the Network after a reflash with a stock-Rom. Is there any solution to make it working also without unlocking after each reflash? |
11-10-2013, 01:39 | #169 (permalink) | |
Freak Poster Join Date: Jul 2011 Location: sweden
Member: 1609777 Status: Offline Thanks Meter: 55 | Quote:
in this way, unfortunately, can not be back network only after using the patch., But I would say that this method is old. now and can with the last update that you change and Repair IMIE ONLY one click and very easily.and can reflash rom with connect to the Network with out patch. thanks | |
11-11-2013, 11:02 | #170 (permalink) |
Member: 1012778 Status: Offline Thanks Meter: 245 | The Unlock doesn't work with SRS: 08:59:28 - Starting ADB Server 08:59:29 - ADB Device: GT-I9300 08:59:29 - SW Version: I9300XXEMG4 (Android: 4.1.2) 08:59:29 - Phone Serial: RV1C62NEKHN 08:59:29 - Platform: exynos4 08:59:29 - Checking SU Root Access.. 08:59:29 - ROOT Access: True (SuperUser) Processing.. 08:59:33 - NVM Readed, Clearing Simlocks Error: New Security (EFSv2) detected, unlock not possible yet. And now??? |
01-28-2014, 16:32 | #172 (permalink) | |
Freak Poster Join Date: Jan 2007 Location: Tanzania Age: 42
Member: 431463 Status: Offline Sonork: 100.1657621 Thanks Meter: 59 | Quote:
THANKSS VERRY MUCH SIR I DID IT WITH 6 PHONE'S..ssss sssssssss ssss sssss s....ss.....ss.....ss.....ss...ss...ss....ss....ss ....ss.....ss....ss.....ss | |
The Following User Says Thank You to ndesa For This Useful Post: |
02-15-2014, 09:05 | #173 (permalink) |
Banned Join Date: Mar 2013 Location: abu dhabi
Member: 1903760 Status: Offline Thanks Meter: 7 | Samsung i9300 imei repair 100% done USB REPAIR IMEI I9300 First install firmware 4.1.2 and root after flash install z3x 16.9 tool then repair with usb its done 100% not any other setting simple ......samsung i9300 imei repair ok.gif Screenshot_2014-02-15-11-54-46.png |
09-09-2014, 10:08 | #176 (permalink) | |
Freak Poster Join Date: Jan 2009
Member: 956406 Status: Offline Thanks Meter: 55 | Quote:
06-24-2016, 15:17 | #178 (permalink) |
Insane Poster Join Date: May 2009
Member: 1035922 Status: Offline Thanks Meter: 2 | This did not work for me 1. Mine is 2012 Samsung Galaxy S3 GT-I9300. It got a bit damaged due to water was lying in my desk for 2 years. This month I opened it and surprisingly it started booting. Screen works. IMEI however shows null 2. I tried odin and your little flash file <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/007> Added!! <ID:0/007> Odin engine v(ID:3.1101).. <ID:0/007> File analysis.. <ID:0/007> SetupConnection.. <ID:0/007> Initialzation.. <ID:0/007> Get PIT for mapping.. <ID:0/007> Firmware update start.. <ID:0/007> SingleDownload. <ID:0/007> efs.img <ID:0/007> NAND Write Start!! <ID:0/007> RQT_CLOSE !! <ID:0/007> RES OK !! <ID:0/007> Remain Port .... 0 <ID:0/007> Removed!! <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/006> Added!! <ID:0/006> Removed!! any suggestions ? IMEI still is null I also tried using the sammymobile stock 4.1.2 but no luck... pls suggest |
