08-19-2014, 19:40 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Namibia
Member: 619878 Status: Offline Thanks Meter: 5 | z3x bot not found winxp vmware i bought z3x box. everything works well except that it says z3x box not found. and GetFTDevicedescription-Invalid handle... in device manager everything is ok. i tried everything what should i do |
08-19-2014, 21:17 | #4 (permalink) |
Junior Member Join Date: Feb 2014 Location: Jamaica
Member: 2125523 Status: Offline Sonork: 100.1652663 Thanks Meter: 2 | What are you using Laptop or desktop? it works best if you keep it connected in one port, if it is a desktop use the port at the back and make sure windows update is on. Install shell and use it to search for drivers. you can PM me if needed to |
08-20-2014, 01:26 | #5 (permalink) |
Member: 2125523 Status: Offline Sonork: 100.1652663 Thanks Meter: 2 | ALL Z3X USERS!! Read this before use BOX! FAQ: Activation, Driver, Access to support. ATENTION! Box is not activated while shipping. DON'T ASK IN FORUM ABOUT ACTIVATION. ACTIVATION CAN DO ONLY RESSELER. Please CONTAKT to your RESSELER FOR ACTIVATION BOX. How install, activate, downloas software. Manual rev.19.10.2008 Download setup,drivers: 1. Download z3x-box setup (drivers, shell): http://z3x-team.com/Enabler/z3x-shell.exe 2. Run z3x-shell.exe. Setup box and card drivers: 4. Connect Z3X-Box to PC 5. Install Z3X-box Drivers from folder x:\Program Files\z3x\Box drivers\ 6. Install Z3X-box Drivers from folder x:\Program Files\z3x\Card drivers\ Activation and registration: don't use ! @ # $ % ^ and any special letter in password - because that is a problem with login from wizzard. 7. Run Z3X-Shell 8. Click "Card" in Z3X_Shell. Wizard will start. 9. Will make all steps from wizard. Download necessary main software: 10. Click "Goto Support" button from Shell and download necessary software. 11. Install downloaded exe. Run. 12. Choice phone model from list and click "Start" Support Forums: forum.z3x-team: Forum Index http://forum.gsmhosting.com/vbb/f453/ Z3x-team(c) 2005-2008 |
08-20-2014, 01:27 | #6 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
you need connect box and setup FTDI drivers. | |
08-20-2014, 05:12 | #7 (permalink) |
Member: 619878 Status: Offline Thanks Meter: 5 | i managed to get a tutorial to setup the drivers correctly, meaning it must show Z3X usb serial driver in device manager. i have the z3x preactivated box from gsm server. i want to use windows xp. i think i do not use the lcorrect driver for that box and operatng system because it still cant see the box which ftdi driver must i use |
