Z3X box [card remove] problem hi z3x team I just bought an z3x box samsung (X edition red) 1 week ago.. whenever I use the USB direct on box it gives me a problem "card removed" then the software was Hang.. even at the first date that I received the Box and the first phone I tried I faced this kind of problem on my new box. at first I ignore it coz I thought it was on the phone problem but the following days, tried another phone to unlock via usb always card removed everytime I plug usb phone direct to the box 5 phone was tried and same problem until today I'm about to unlock S5570 http://i40.tinypic.com/2pq84tv.jpg I can only succed when I direct the usb from PC to phone I try also to plug the box into other usb port of my pc but same problem should I return it the box to my reseller? here is the other screen shot http://i42.tinypic.com/16lzig2.jpg http://i39.tinypic.com/ngc5cy.jpg please advice if I have to return it or do you have solution that you can share. |
where is the team? . . . . . . . . . . . . |
May be you have Box hardware Problem or USB Main A 2 B Cable If your Box Not in Warrenty .. Remove smart card and Put in another box and try it I am not Sure . Check this first . Regards Avatorbox |
gpg z3x box bed card remove card remove kya hoga iska koi |
BR. Arsalan gsm2000. |
This is main cable problem, use original cable not like printer cable. also don't let your box while you working if box connection loose this problem comes,. |
I Also facing same problem, my box its GPG version.... |
read above, change usb cable between box and pc. And NEVER use usb port from box ! Also don't plug rj45 after soft started detection. Any bad contact when touching or moving box can produce this "card removed" problem. BR |
Already tried, with cable Y A-B, same problem, already tried with pkey reader and z3x box as interface, and now box get disconnected... Conclusion... GPG z3x box *****.. |
Check power options -> usb selective power option -> disable |
same issue I have a gpg version , same issue I am facing. Ordered for New Z3X without card . Hopefully it'll work. |
