Old 12-31-2011, 08:50   #1 (permalink)
PedaLBoard's Avatar
Member: 1317565
Thanks Meter: 61
Z3X box [card remove] problem
hi z3x team
I just bought an z3x box samsung (X edition red) 1 week ago..
whenever I use the USB direct on box
it gives me a problem "card removed" then the software was Hang..
even at the first date that I received the Box
and the first phone I tried
I faced this kind of problem on my new box.
at first I ignore it coz I thought it was on the phone problem
but the following days, tried another phone to unlock via usb
always card removed everytime I plug usb phone direct to the box
5 phone was tried and same problem
until today I'm about to unlock S5570
I can only succed when I direct the usb from PC to phone
I try also to plug the box into other usb port of my pc but same problem
should I return it the box to my reseller?
here is the other screen shot
please advice if I have to return it or do you have solution that you can share.
Old 12-31-2011, 11:52   #2 (permalink)
PedaLBoard's Avatar
Member: 1317565
Thanks Meter: 61
where is the team? . . . . . . . . . . . .
Old 12-31-2011, 12:17   #3 (permalink)
Member: 1427447
Sonork: 100.1596998
Thanks Meter: 4,178
May be you have Box hardware Problem or USB Main A 2 B Cable
If your Box Not in Warrenty .. Remove smart card and Put in another box and try it
I am not Sure . Check this first .
Regards
Avatorbox
The Following User Says Thank You to Avatorbox For This Useful Post:
Old 01-02-2012, 06:59   #4 (permalink)
PedaLBoard's Avatar
Member: 1317565
Thanks Meter: 61
my box is still in warranty coz I bought it a week ago..
Old 11-30-2012, 08:20   #5 (permalink)
Member: 1661299
Sonork: 100.1622657
Thanks Meter: 31
gpg z3x box bed card remove card remove kya hoga iska koi
Old 11-30-2012, 12:59   #6 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,134
1st Confirm Here Z3x Brand You Use Mr.Blang OR GPG?
BR.
Arsalan gsm2000.
The Following 3 Users Say Thank You to .::MASTER ALONE::. For This Useful Post:
Old 11-30-2012, 17:06   #7 (permalink)
snmobilecenter's Avatar
Member: 983663
Sonork: 100.1623270
Thanks Meter: 528
This is main cable problem, use original cable not like printer cable.
also don't let your box while you working if box connection loose this problem comes,.
Old 12-03-2012, 16:14   #8 (permalink)
yusniel's Avatar
Member: 1537172
Thanks Meter: 49
I Also facing same problem, my box its GPG version....
Old 12-03-2012, 16:17   #9 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Thanks Meter: 439
read above, change usb cable between box and pc.
And NEVER use usb port from box !
Also don't plug rj45 after soft started detection.
Any bad contact when touching or moving box can produce this "card removed" problem.
Old 12-03-2012, 16:33   #10 (permalink)
yusniel's Avatar
Member: 1537172
Thanks Meter: 49
Already tried, with cable Y A-B, same problem, already tried with pkey reader and z3x box as interface, and now box get disconnected...
Conclusion... GPG z3x box *****..
Old 10-12-2017, 18:19   #11 (permalink)
Member: 1054645
Thanks Meter: 7
Check power options -> usb selective power option -> disable
Old 10-12-2017, 18:26   #12 (permalink)
Member: 2463805
Thanks Meter: 18
same issue
I have a gpg version , same issue I am facing. Ordered for New Z3X without card . Hopefully it'll work.
SIM card readers Ryu Hardware Equipments for GSM 7 10-30-2007 09:11
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Page generated in 0.30778 seconds with 8 queries
