05-25-2013, 08:22 | #1 (permalink) |
Junior Member Join Date: May 2013
Member: 1938060 Status: Offline Sonork: 100.1638670 Thanks Meter: 19 | Z3X BOX GT-I9505 (Galaxy S4 Qualcomm) / Unlock / Repair IMEI Full DONE and Easy.... 2. *#0808# - DM - MODEM - ADB 3. *#9090# - DM OVER UART[*] 4. Connect Phone Z3X Box And Wait install Driver (USB CABLE) 5. Select Z3X Serial COM Port (Yes, Select Z3x Port) 6. Press REPAİR Button and Write IMEI Number 7. Wait, Reboot Pohone 8. Reboot After Connect Standart UART Cable and Wait.. 9. Done ))) If you make just USB cable.. IMEI =0 but repair IMEI File System.. Second Step UART Cable.. Write IMEI and All Done.. NO NEED DIFFERENT UART OR USB CABLE..! JUST SELECT PHONE UART COMINICATION 9090 |
The Following 8 Users Say Thank You to ufukkoktas For This Useful Post: |
05-25-2013, 18:38 | #5 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mongarrasco
Member: 107027 Status: Offline Thanks Meter: 269 | thank's for your guide bro. have you noticed, after imei repair, network registration is a little slow than in "normal" condition? have you tried to write another firmware after repaired? same problem like s3? no network? which file have you used to root the phone? thanks in advance bro br ss |
The Following User Says Thank You to agentot For This Useful Post: |
05-25-2013, 18:45 | #6 (permalink) |
Crazy Poster Join Date: Apr 2005 Age: 48
Member: 136882 Status: Offline Thanks Meter: 16 | IMEI repair Confirmed. Works like a charm (:-). Yes registration is a little bit slower but still network after flashing of different firmware (update still not available). Most important is to set *#7284# to PDA elsewise UART does not recognise the phone after reboot and IMEI ends in null... Thx again |
05-29-2013, 19:21 | #8 (permalink) |
Junior Member Join Date: May 2013 Location: UK
Member: 1949494 Status: Offline Thanks Meter: 3 | I have like : Selected model: I9105 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Please, allow USB debugging on phone... Reading phone info... Model: GT-I9505 Android version: 4.2.2 Product code: GT-I9505ZKABTU Phone version: I9505XXUAMDM PDA version: I9505XXUAMDM CSC version: I9505OXXAMDB IMEI: Unknown Checking Super user right... true Reading data from phone... OK Repairing... OK Rebooting phone... OK Repair done Done with Samsung Tool v.14.5 And is not asking to connet uart. just reboot it self and IMEI still not repair. Any IDEA why? |
05-29-2013, 20:03 | #9 (permalink) | |
Member: 1949494 Status: Offline Thanks Meter: 3 | Quote:
Selected model: I9505 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9505 Android version: 4.2.2 Product code: GT-I9505ZKABTU Phone version: I9505XXUAMDM PDA version: I9505XXUAMDM CSC version: I9505OXXAMDB IMEI: Unknown Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Now connect phone to UART cable Checking phone at COM4 OK Reading phone info... Model: GT-I9505 Country code: BTU Cal date: - Factory SW: I9505XXUAMDM Unique number: Memory phone: - Bypass MSL... OK Repairing IMEI... OK Rebooting... OK Repair done Done with Samsung Tool v.14.6 Selected model: I9505 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Phone not found Done with Samsung Tool v.14.6 ALL OK!!!!!! THX Z3X | |
05-30-2013, 20:35 | #10 (permalink) | |
Member: 1938060 Status: Offline Sonork: 100.1638670 Thanks Meter: 19 | Quote:
05-31-2013, 01:02 | #12 (permalink) |
Major Poster Join Date: May 2013
Member: 1950704 Status: Offline Thanks Meter: 4 | work 100% funciona al 100% Se neserario el root Lo descargamos http://es.ready2root.com/info/galaxy-s4-i9505 es muy fácil de instarlar abrimos el odin e instalamos el en PDA el archivo .md5 conectamos el s4 en modo download y en 30 seg root para repara imei es necesario estos 2 pasos 1. *#0808# - DM - MODEM - ADB 2. *#9090# - DM OVER UART[*] ( es la opcion 4) Ahora conectamos el s4 (i9505) En modo depuración de datos (mediante cable usb) Ruta: ajustes/mas/acerca del dispositivo/numero de compilación (hay damos 7 toques y se activa el modo depuración de datos) Le damos a repair e introducimos el numero de imei Y cuando nos pida que cambiemos a cable micro uart (c3300) Solo cambiamos el cable y listo , cuando reinicie el móvil esta el imei reparado Tarda unos minutos en coger la red no te preocupes es normal Selected model: I9505 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9505 Android version: 4.2.2 Product code: GT-I9505ZWAPHE Phone version: I9505XXUAMDE PDA version: I9505XXUAMDE CSC version: I9505OXXAMD8 IMEI: Unknown Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Now connect phone to UART cable Checking phone at COM4 OK Reading phone info... Model: GT-I9505 Country code: PHE Cal date: - Factory SW: I9505XXUAMDE Unique number: CAF00C40999FF30 Memory phone: - Bypass MSL... OK Repairing IMEI... OK Rebooting... OK Repair done Done with Samsung Tool v.14.6 |
06-22-2013, 13:01 | #15 (permalink) |
No Life Poster Join Date: Dec 2008 Location: costa rica
Member: 917285 Status: Offline Sonork: damond Thanks Meter: 31 | hi when i type *#9090# it only says service mode, you can check it over here http://forum.gsmhosting.com/vbb/f453...0/#post9517945 |
