06-27-2013, 13:09 | #16 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: SOUTH AFRICA
Member: 220491 Status: Offline Thanks Meter: 14 | Quote:
06-27-2013, 22:55 | #19 (permalink) |
Freak Poster Join Date: Dec 2009 Location: UK. Worcester Age: 35
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | i9505 imei repair done!: 1. USB debuging on 2. Root manualy with CF-Auto-root (flashed via ODIN in PDA section) 3. *#7284# - set "UART" to PDA (Default is PDA) 4. *#0808# - set "USB" to AP (Default is AP) ,,,, set "USB settings" to DM+MODEM+ADB (Default is MTP) 5. *#9090# - select "[4]DM over UART(*)" ,,,, phone will reboot. 6. Connect phone with usb (install drivers if needed) 7. Select box comport in z3x 8. Repair button in z3x, fill IMEI. Phone will check for root, write data, then it will reboot. After reboot connect phone with c3300k microUART rj45 cable (if its stuck on "Checking phone at COMxx..." then quickly *#9090# - "DM over UART", u should have enough time to reboot phone while z3x still searching on comport). z3x will write IMEI and reboot phone. All done!. Phone may search for network little bit longer but it will sign into network after while (max 2mins). Code: Selected model: I9505 Selected port: COM18 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9505 Android version: 4.2.2 Product code: Not Active Phone version: I9505XXUAMDM PDA version: I9505XXUAMDM CSC version: I9505OXXAMDB IMEI: Unknown Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Now connect phone to UART cable Checking phone at COM18 OK Reading phone info... Model: GT-I9505 Country code: BTU Cal date: - Factory SW: I9505XXUAMDM Unique number: CAF001707121230 Memory phone: - Bypass MSL... OK Repairing IMEI... OK Rebooting... OK Repair done Done with Samsung Tool v.14.9 |
The Following User Says Thank You to Thorenzz For This Useful Post: |
06-28-2013, 03:21 | #20 (permalink) | |
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | Quote:
07-02-2013, 02:17 | #21 (permalink) |
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | Another i9505 imei repair done! Thanks z3x team 1. USB debuging on 2. Root manualy with CF-Auto-root (flashed via ODIN in PDA section) 3. *#7284# - set "UART" to PDA (Default is PDA) 4. *#0808# - set "USB" to AP (Default is AP) ,,,, set "USB settings" to DM+MODEM+ADB (Default is MTP) 5. *#9090# - select "[4]DM over UART(*)" ,,,, phone will reboot. 6. Connect phone with usb (install drivers if needed) 7. Select box comport in z3x 8. Repair button in z3x, fill IMEI. Phone will check for root, write data, then it will reboot. After reboot connect phone with c3300k microUART rj45 cable (if its stuck on "Checking phone at COMxx..." then quickly *#9090# - "DM over UART", u should have enough time to reboot phone while z3x still searching on comport). z3x will write IMEI and reboot phone. All done!. Phone may search for network little bit longer but it will sign into network after while (max 2mins). I was experiencing some troubles to get 3G working properly. However, after flash of firmware and wipe data and cache afterwards everything works as it should, expect that phone is searching for network one minute, max two (WEIRD). LOG: Code: Selected model: I9505 Selected port: COM18 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9505 Android version: 4.2.2 Product code: Not Active Phone version: I9505XXUAMDM PDA version: I9505XXUAMDM CSC version: I9505OXXAMDB IMEI: Unknown Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Now connect phone to UART cable Checking phone at COM18 OK Reading phone info... Model: GT-I9505 Country code: O2U Cal date: - Factory SW: I9505XXUAMDM Unique number: CAF00D0198EE940 Memory phone: - Bypass MSL... OK Repairing IMEI... OK Rebooting... OK Repair done Done with Samsung Tool v.14.9 Done with Samsung Tool v.14.9 |
07-04-2013, 17:37 | #22 (permalink) |
No Life Poster Join Date: Apr 2004
Member: 61389 Status: Offline Thanks Meter: 193 | Hello I have three brand new i9505, untouched I follow Thorenzz manual. One of these is succesfully repaired. Two is impossible to detect in uart Exactly same flash(4 parts orig. flash not the one package, flashed with odin and with pit), same root and same repair steps. Tested with two different pc, two different z3x box and one nspro (and yes after first reboot--> *#9090# --> choose uart--> reboot) Before the operation the uart cable work : Code: Selected model: I9505 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Done with Samsung Tool v.15.0 Code: Selected model: I9505 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9505 Android version: 4.2.2 Product code: Not Active Phone version: I9505XXUAMDF PDA version: I9505XXUAMDF CSC version: I9505OXXAMD8 IMEI: Unknown Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Now connect phone to UART cable Checking phone at COM3 No answer from phone Done with Samsung Tool v.15.0 Code: Selected model: I9505 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Done with Samsung Tool v.15.0 thx |
07-05-2013, 11:43 | #23 (permalink) | |
07-05-2013, 13:34 | #24 (permalink) |
Member: 61389 Status: Offline Thanks Meter: 193 | thx but all steps checked many time, reflashed and tried with 14.6, 14.7, 14.8, 14.9 15.0 and nspro, different z3x boxes, different pc-s and i guess i was tried all combination. Last edited by jodge; 07-05-2013 at 13:40. |
07-05-2013, 14:48 | #25 (permalink) |
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | Sorry i cant help in that case, but i managed to do 3 units allready with mine method posted above. Andother thing to mention is that i tried so many times on NSPRO and OCTOPUS without any success. I managed to repair IMEI only with z3x box. |
07-05-2013, 16:38 | #26 (permalink) |
Member: 61389 Status: Offline Thanks Meter: 193 | Now i replaced the resistor in the cable (530k to variable resistor ) cca. 520-526k (every phone work with different value weird) the operation succes both in z3x and ns but the imei still 0/01 ofcourse i repeated the whole operation (flash+root..blabla) i confused |
08-01-2013, 11:49 | #28 (permalink) |
Freak Poster Join Date: Jan 2004 Location: POLAND Age: 52
Member: 49368 Status: Offline Thanks Meter: 28 | Root with NSpro Working Unlock OK BY USB Cabel Selected model: I9505 Selected port: COM297 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.15.1 Done with Samsung Tool v.15.1 |
08-01-2013, 21:14 | #29 (permalink) |
Insane Poster Join Date: Nov 2009 Location: hyderabad
Member: 1166487 Status: Offline Sonork: 100.1673527 Thanks Meter: 7 | sgh s4 i9505 work 100% funciona al 100% Se neserario el root Lo descargamos http://es.ready2root.com/info/galaxy-s4-i9505 es muy fácil de instarlar abrimos el odin e instalamos el en PDA el archivo .md5 conectamos el s4 en modo download y en 30 seg root para repara imei es necesario estos 2 pasos 1. *#0808# - DM - MODEM - ADB 2. *#9090# - DM OVER UART[*] ( es la opcion 4) Ahora conectamos el s4 (i9505) En modo depuración de datos (mediante cable usb) Ruta: ajustes/mas/acerca del dispositivo/numero de compilación (hay damos 7 toques y se activa el modo depuración de datos) Le damos a repair e introducimos el numero de imei Y cuando nos pida que cambiemos a cable micro uart (c3300) Solo cambiamos el cable y listo , cuando reinicie el móvil esta el imei reparado Tarda unos minutos en coger la red no te preocupes es normal Selected model: I9505 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9505 Android version: 4.2.2 Product code: GT-I9505ZWAPHE Phone version: I9505XXUAMDE PDA version: I9505XXUAMDE CSC version: I9505OXXAMD8 IMEI: Unknown Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Now connect phone to UART cable Checking phone at COM4 OK Reading phone info... Model: GT-I9505 Country code: PHE Cal date: - Factory SW: I9505XXUAMDE Unique number: CAF00C40999FF30 Memory phone: - Bypass MSL... OK Repairing IMEI... OK Rebooting... OK Repair done Done with Samsung Tool v.14.6 |
08-05-2013, 09:12 | #30 (permalink) |
Insane Poster Join Date: Sep 2005 Location: Hungary, Budapest Age: 45
Member: 183034 Status: Offline Thanks Meter: 12 | The imei is null null. I can't repair this phone. Is it HW issue? Selected model: I9505 Selected port: COM10 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9505 Android version: 4.2.2 Product code: Unknown Phone version: Unknown PDA version: I9505XXUAMDM CSC version: I9505OXAAMDM IMEI: Unknown Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Checking phone at COM10 OK Repairing IMEI... error Reseting... OK Repair done Done with Samsung Tool v.15.2 Done with Samsung Tool v.15.2 |
