Old 11-07-2018, 16:38   #151 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Originally Posted by luisnegociador9 View Post
hello. i paid 30 credits and not work apn. in ls992zvf
i need apn in ls992zvf
Hi,
we release unlock functions, we can't release APN edit function.
Old 11-07-2018, 19:47   #152 (permalink)
reyxito's Avatar
Member: 2549748
Thanks Meter: 212
Originally Posted by andrew_tm View Post
Hi,
If phone on Android 7 we can add remote.
I have ls998 but with Android oreo
Old 11-07-2018, 19:57   #153 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Currently no way.
Old 11-08-2018, 00:13   #154 (permalink)
Member: 1892086
Sonork: 1671742
Thanks Meter: 282
i have an error unlocking m150 20M
Old 11-08-2018, 03:19   #155 (permalink)
Member: 2679051
Thanks Meter: 4
Waiting for APN solution, actually without APN is a waste of money to spend credits .. worthless unlock
Old 11-08-2018, 07:42   #156 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
Please make normal screen shot.
Old 11-08-2018, 17:39   #157 (permalink)
Member: 2681434
Sorry am looking for x410tk root, any idea??
Enviado desde mi iPhone utilizando Tapatalk
Old 11-08-2018, 17:54   #158 (permalink)
Member: 1892086
Sonork: 1671742
Thanks Meter: 282
ok i will next time, i still have this error, dont know why
Old 11-08-2018, 21:17   #159 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
You can send team viewer id and pass to me in PM. I can check your problem.
Old 11-09-2018, 03:51   #160 (permalink)
Registered User
Member: 2800369
please help i have 3 pcs stylo 3 ls777 android 7, z3x lg ask for root to unlock the phone. is there any other way to unlock.
Old 11-09-2018, 05:51   #161 (permalink)
Member: 92260
Thanks Meter: 843
To enable APN on Sprint LG phones
Hi,
Sprint unlock works fine for the most part, but to enable APN here are some suggestions:
In Hidden Menu > IOT/CDG2 > LTE > Operation Mode change Production Network to Lab Network.
Or restart with a Sprint SIM card inserted, select network, then replace with user SIM.
To enable diag/hidden menu:
GSM
277634#*# (diag)
2945#*<model#># (unlock)
3845*#<model#># (diag)
159753#*<model#># (diag)
*#546368#*<model#># (diag)
*#865625# (unlock)
Verizon
##228378 + Call
##5473784236368 + Call
##7764726<model#> + Call
Sprint
5689#*<mode#>#
##3424# + SPC code
##8378# + SPC code
You can try to following ADB activities (not all will work, but worth a try):
adb shell am start com.lge.SprintHiddenMenu/com.lge.SprintHiddenMenu.iot.IotHiddenMenuMain
adb shell am start com.lge.networksettings/com.lge.networksettings.MobileNetworkSettings
adb shell am start com.lge.networksettings/.MobileNetworkSettingsForGLOBAL
adb shell am start com.lge.networksettings/.msim.MSimMobileNetworkSubSettings
LTE Service Disabled fix
Insert an original SIM, and the network option will be enabled so it can be changed manually.
OR
Using Quick Shortcuts search for "mobile", Mobile Networks, Network Selection, GSM/UMTS.
OR
Data fix
5689#*<model#>#
Field Test > NAO Test > NAOT > NAO Setting > NAO Carrier > SPR/None
Field Test > NAO test > NAOT > NAO Setting > NAO Test Toggle > NAO Carrier > SPR/None
No upload data fix
Unlock
##786# reset
Unlock again
Disable hands-free
Set APN to IPv4/v6 with TMO
OR
Reset SEC partition
HFA/Hands Free Activation popup disable
adb shell pm uninstall -k --user 0 com.android.LGSetupWizard
adb shell pm uninstall -k --user 0 com.lge.activation
adb shell pm uninstall -k --user 0 com.LogiaGroup.LogiaDeck
The Following 4 Users Say Thank You to BillA For This Useful Post:
Old 11-09-2018, 17:46   #162 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
GSM
277634#*# (diag)
*#865625# (unlock)
Verizon
##228378 + Call
Sprint
5689#*<mode#>#
##3424# + SPC code
##8378# + SPC code
OR
OR
Data fix
5689#*<model#>#
No upload data fix
Unlock
##786# reset
Unlock again
Disable hands-free
OR
Reset SEC partition
Thanks to Sprint guru
The Following User Says Thank You to andrew_tm For This Useful Post:
Old 11-09-2018, 22:27   #163 (permalink)
Member: 2865077
hello again.
i reset ls992zvf and lose unlock.
i need your help
Old 11-09-2018, 22:28   #164 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
hello again.
i need your help
Unlock again. After this send unlock log to me in PM and we refund your previous credits in next 12 hours.
Old 11-09-2018, 22:42   #165 (permalink)
Member: 2865077
i dont have credits.
help me
Page generated in 0.49075 seconds with 10 queries
