11-09-2018, 05:51 | #161 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | To enable APN on Sprint LG phones Quote:
Sprint unlock works fine for the most part, but to enable APN here are some suggestions: In Hidden Menu > IOT/CDG2 > LTE > Operation Mode change Production Network to Lab Network. Or restart with a Sprint SIM card inserted, select network, then replace with user SIM. To enable diag/hidden menu: GSM ----- 277634#*# (diag) 2945#*<model#># (unlock) 3845*#<model#># (diag) 159753#*<model#># (diag) *#546368#*<model#># (diag) *#865625# (unlock) Verizon -------- ##228378 + Call ##5473784236368 + Call ##7764726<model#> + Call Sprint ------- 5689#*<mode#># ##3424# + SPC code ##8378# + SPC code You can try to following ADB activities (not all will work, but worth a try): adb shell am start com.lge.SprintHiddenMenu/com.lge.SprintHiddenMenu.iot.IotHiddenMenuMain adb shell am start com.lge.networksettings/com.lge.networksettings.MobileNetworkSettings adb shell am start com.lge.networksettings/.MobileNetworkSettingsForGLOBAL adb shell am start com.lge.networksettings/.msim.MSimMobileNetworkSubSettings LTE Service Disabled fix -------------------------- Insert an original SIM, and the network option will be enabled so it can be changed manually. OR Using Quick Shortcuts search for "mobile", Mobile Networks, Network Selection, GSM/UMTS. OR adb shell am start com.lge.networksettings/com.lge.networksettings.MobileNetworkSettings Data fix --------- 5689#*<model#># Field Test > NAO Test > NAOT > NAO Setting > NAO Carrier > SPR/None Field Test > NAO test > NAOT > NAO Setting > NAO Test Toggle > NAO Carrier > SPR/None No upload data fix -------------------- Unlock ##786# reset Unlock again Disable hands-free Set APN to IPv4/v6 with TMO OR Reset SEC partition HFA/Hands Free Activation popup disable ---------------------------------------------- adb shell pm uninstall -k --user 0 com.android.LGSetupWizard adb shell pm uninstall -k --user 0 com.lge.activation adb shell pm uninstall -k --user 0 com.LogiaGroup.LogiaDeck Last edited by BillA; 11-09-2018 at 05:58. | |
The Following 4 Users Say Thank You to BillA For This Useful Post: |
11-09-2018, 17:46 | #162 (permalink) | |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Quote:
The Following User Says Thank You to andrew_tm For This Useful Post: |
