08-09-2012, 14:37 | #1 (permalink) |
Insane Poster Join Date: Aug 2012
Member: 1795462 Status: Offline Thanks Meter: 8 | Z3x box not detecting phone!! Plz help me!! I have recently purchased my Z3X box, i followed all the procedures of setting it up. Downloaded ZX3 Shell, installed drivers as instructed and downloaded phone drivers (also installed Kies). I have tried on four diffent OS... My problem is that when i connect my phone (n7000 Galaxy note) to the z3x box using the samsung tool via usb cable, i click on read info and i get the following: Count supported models - 309 Searching Samsung USB Modem... Not Found Done with Samsung Tool ver 12.5 but when i connect the phone directly to my computer then i get the follwing: Searching Samsung USB Modem... Detected (COM5) Model: GT-N7000 SW: N7000XXKJ4 IMEI: 3595750486xxxxx Done with Samsung Tool ver 12.5 Im trying to repair IMEI but all i get is the same error 'Searching Samsung USB Modem... Not Found' Could it be a problem with my drivers or could it be the firmware on my phone? i am using Windows Vista Home Premium 32bit Please please get back in touch as i have spent 3 days and 3 nights trying to configure this.. Much appreciated! |
08-09-2012, 17:18 | #3 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | First, always connect phones directly to computer, no hub or switch or box (except rj45 but I speak for usb here) Then, try to repair efs first, then change imei. Anyway, post full log of your tries so we can see clearer what you did and how we can help. BR |
The Following User Says Thank You to cycofcgb For This Useful Post: |
08-09-2012, 20:10 | #4 (permalink) |
Member: 1795462 Status: Offline Thanks Meter: 8 | hi, I have now connected my phone direct (usb) without connecting via the z3x. I get the following; Phone Not Found Done with Samsung Tool ver 12.7 that is with repair EFS box checked. |
08-09-2012, 20:28 | #5 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | what is wrong with imei ? seems regular on your first post ? did you enable usb debugging on phone ? Saw on other post that you might have success with v11.9 of tool. Maybe you need also to flash your phone. |
08-09-2012, 23:06 | #6 (permalink) |
Member: 1795462 Status: Offline Thanks Meter: 8 | Thanks again for your swift reply, I will download v11.9 and also flash firmware and see if it makes a difference. Thanks again for your support! Sent from my GT-I9300 using Tapatalk 2 |
08-10-2012, 07:43 | #9 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | This one was succesful for someone in here : Hotfile.com: One click file hosting: N7000XXKJ4_N7000DREKJ2_DRE.zip pass : **************** If you need further help for flashing your set, feel free to ask. Btw, general info for you, when you use unlocking boxes, vista is not a good choice. Try to find an other pc with xp sp3, no antivirus, no firewall, and you will use this computer only for unlocking purposes. So you will avoid many compatibility problems with all the craps we all install on main pc |
08-10-2012, 17:42 | #10 (permalink) |
Member: 1795462 Status: Offline Thanks Meter: 8 | Hi I have updated the firmware as instructed by yourself without success, it still says phone not found, so im going to reinstall my computer with windows xp sp3 and see if that will make a difference. Thanks JZK |
08-10-2012, 18:37 | #11 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | to flash your set use odin v1.85, and for the drivers just install kies. |
01-16-2017, 16:24 | #15 (permalink) |
Insane Poster Join Date: Feb 2008 Location: FRANCE Age: 44
Member: 709142 Status: Offline Sonork: 100.114099 Thanks Meter: 17 | 920f repaire done Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM8 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Recovery build version: 6.0.1 Boot version: G920FXXS4DPIU Platform: exynos7420 Boot serial: XXXXXXXXXXXXXXX Product board: zerolte Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Checking DRK status... Ok Repairing DMVT key... Ok Rebooting phone... Ok Repair DRK done Done with Samsung Tool PRO v.27.7 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
