03-10-2016, 05:20 | #1 (permalink) |
Insane Poster Join Date: Mar 2016
Member: 2543524 Status: Offline Thanks Meter: 11 | Z3x box a novice Sorry I'm currently new to this and was recommending this site by a fellow user but I tend to have a lot of questions and was wondering if someone can point me in the right direction, as well thanks for advance. Box that i use is a z3x box. questions: 1. To repair imei on S6edge T-Mobile phone must be rooted, I have that down but one of the instructions said wipe esf, I already have a cert file for the device, someone said don't touch it and to use write cert file, and after that I got lost...... 2. Is there any solution to HTC GOOGLE FRP/ OR ZTE GOOGLE FRP? 3. is there any tutorials or videos on regards more in depth with the Z3X BOX Thanks and appreciate hopefully someone point me in the right direction. |
03-10-2016, 05:41 | #2 (permalink) | |
Freak Poster Join Date: Dec 2012 Location: The North
Member: 1861077 Status: Offline Thanks Meter: 89 | Quote:
BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Does it say anything about WIPE EFS? 2. There is a solution for FRP for HTC and ZTE but not by Z3X. 3. Again all instructions are included in most of the renowned tools as I posted above what it shows under Z3X instructions. Now if you just bought z3x and expect to master it without reading forums and other people DOs and DONTs then I am not sure you can learn this tool. Search the forum see what other users have done, and they succeeded and what they did and failed and how they resolve it. Read read and read. Good Luck | |
03-10-2016, 05:49 | #3 (permalink) |
Member: 2543524 Status: Offline Thanks Meter: 11 | i appreciate your wisdom and your knowledge towards the box, just wanting to double check, might have been have confused or mislead on what the person has told me, right just follow instructions that the box gives ....... thanks once again and appreciate it once again and yes i have purchased the box have little time with it....i just do the simple things like direct unlock or google frp ....once again thanks |
