10-31-2014, 21:17 | #111 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: Lima - Perú
Member: 598854 Status: Offline Thanks Meter: 141 | Quote:
Selected model: SM-G355H Selected port: COM912 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SM-G355H Android version: 4.4.2 Product code: SM-G355HZKACHE Phone version: G355HUHU0ANH1 PDA version: G355HXXU0ANH1 CSC version: G355HCHE0ANH1 IMEI: 355428060374232 Phone S/N: R21F90321TN Checking Super user right... true Detecting NV partitions... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.18.3 | |
10-31-2014, 21:23 | #112 (permalink) |
Major Poster Join Date: Mar 2014
Member: 2150078 Status: Offline Thanks Meter: 18 | Selected model: SM-G900T1 Selected port: COM1009 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Checking certificate file... OK Searching ADB device... OK Reading phone info... Model: SM-G900T1 Android version: 4.4.2 Product code: Not Active Phone version: G900T1UVU1ANCI PDA version: G900T1UVU1ANCI CSC version: G900T1TMB1ANCI IMEI: Unknown Phone S/N: RV8F40DD8ZK Checking Super user right... true Bypass MSL... OK Checking for compatible phone and cert... error This CERT file is not compatible for this phone Done with Samsung Tool v.18.3 I am using G900H and G900F cert and does not work for G900T1, what is the problem?????? I have wiped EFS and imei is unknown, and I get error "phone has been flashed with unauthorized software" |
10-31-2014, 22:42 | #113 (permalink) | |
Freak Poster Join Date: Nov 2013 Location: remotely
Member: 2063388 Status: Offline Thanks Meter: 80 | Quote:
11-01-2014, 01:14 | #115 (permalink) | |
Member: 2150078 Status: Offline Thanks Meter: 18 | Quote:
If you don't have the solution for something stop demanding from z3x, they have provided us first world solutions before most companies, and they don't have a update limit like other companies where you have to repay, be a little appreciative. If you don't want to lose imei and just unlock go and pay for Uart unlock for $14 each from octopus. Goodbye | |
11-01-2014, 03:56 | #117 (permalink) | |
No Life Poster Join Date: Aug 2013 Location: Somewhere on earth
Member: 2014742 Status: Offline Thanks Meter: 167 | Quote:
The Following User Says Thank You to A4L For This Useful Post: |
11-01-2014, 09:32 | #119 (permalink) |
Freak Poster Join Date: May 2014 Location: Turkey/İzmir
Member: 2187028 Status: Offline Thanks Meter: 21 | Hi Z3X team help pls Selected model: SM-G900FQ Selected port: COM63 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0xCE9088C0 Searching USB Flash Interface... detected COM12 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\SM-G900FQ_1-11-2014_10-21-3.pit Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending sdi.mbn... OK Sending NON-HLOS.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Sending modem.bin... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending sdi.mbn... OK Sending NON-HLOS.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Sending modem.bin... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending sdi.mbn... OK Sending NON-HLOS.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Sending modem.bin... Error Done with Samsung Tool v.18.3 |
