07-22-2014, 10:42 | #1 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 539679 Status: Offline Thanks Meter: 468 | Z3X Box working on windows 8.1 64bit (Guide) First Disable Driver Signature Enforcement in Windows 8 Select "Settings / Change PC Settings (at bottom) / General / Advanced Startup - Restart Now (at bottom) Then go "Troubleshoot / Advanced Options / Windows Startup Settings - Restart" After restart select Disable driver signature enforcement (F7). When your pc will started you can install any driver you want. Or Follow This Video. How to Disable Driver Signature Enforcement in Windows 8 - YouTube after enforcement install Z3x shell / samsung tools etch. plug in the z3x box into Pc install manually Box driver under c/programfiles/z3x/box driver after box install u have rcv this error The usb serial port not install properly or driver not match. No need to worry Follow image instruction how to install driver . image upload upload image online pic host image upload no size limit uploading pictures how to screenshot on windows 7 now try if box can detect cellphone via USB or Rj45. try set samsung galaxy Y 5360 and att i7i7. Via USB Galaxy Y5360 working smooth. free upload pictures Via RJ45 using c3303 cable att i717 working. pic hosting Smart card no Issue use z3x folder smart card driver. |
The Following 4 Users Say Thank You to rodbautis For This Useful Post: |
06-21-2015, 01:03 | #8 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2403062 Status: Offline Thanks Meter: 5 | it basically identical install on any 64 bit windows. same serial driver work on 7/8/8.1 and video setup same for FTDI, only smart card install different. You say USB work and UART not work? are you sure none hardware problem? |
12-01-2015, 13:26 | #11 (permalink) |
Freak Poster Join Date: Aug 2011 Location: Austria Turkey Germany
Member: 1636473 Status: Offline Thanks Meter: 19 | bevor i install driver: https://imgur.com/2btJsWX After install driver: https://imgur.com/zZLMtNy Box is working very well but only port is not working.... after install also not working! |
