10-19-2015, 17:47 | #1 (permalink) |
Freak Poster Join Date: Feb 2015 Location: L&J_CUBA
Member: 2352896 Status: Offline Thanks Meter: 116 | Z3X can unlock s6 edge+ T-mobile G928T??? You said this: - support SM-G928T (Flash, Read/Write/Reset EFS, Read/Write CERT, reboot to download recovery) - 1st in the world It's true??? Thanks in advance |
10-19-2015, 19:49 | #5 (permalink) |
Junior Member Join Date: Apr 2013 Location: 393 E 149thst Bronx NY 10458
Member: 1925224 Status: Offline Thanks Meter: 2 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 5. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 6. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-G928T Software version: 23.0 Waiting ADB device... OK Reading phone info... Model: SM-G928T Android version: 5.1.1 Product code: SM-G928TZDATMB Phone version: G928TUVU1AOGD PDA version: G928TUVU1AOGD CSC version: G928TTMB1AOGD CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone S/N: R58G7296Y3T Modem board: SHANNON333 RF cal date: 20150731 IMEI: Checking Super user right... true Checking certificate file... OK KEY ID: 0784 Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.23.0 CERT WRITE WORKS =D |
10-19-2015, 20:11 | #6 (permalink) |
Member: 1925224 Status: Offline Thanks Meter: 2 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-G928T Software version: 23.0 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G928T Android version: 5.1.1 Product code: SM-G928TZDATMB Phone version: G928TUVU1AOGD PDA version: G928TUVU1AOGD CSC version: G928TTMB1AOGD CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone S/N: R58G7296Y3T Modem board: SHANNON333 RF cal date: 20150731 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:10) Freeze code: 42804807 NET lock: 07295752 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.23.0 |
