11-28-2009, 22:49 | #1 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1152345 Status: Offline Thanks Meter: 9 | z3x card driver I contacted my reseller and they pointed me here for help. The box driver is installed ok, the card driver can not be installed but it's activated and updated ok when I run shell app. I go to device manager to check device installed, there's eclamaiton mark at "USB serial converter" device. Please explain me what it is ASAP. thanks |
11-28-2009, 23:03 | #2 (permalink) |
No Life Poster Join Date: Oct 2008 Location: HPS
Member: 878925 Status: Offline Sonork: ;-) Thanks Meter: 786 | Hi , open Control panel > device manager what you see can you see smart card reader - e/gate usb smart card reader if yes unistall it than restart your pc and install again from the folder C:\Program Files\Z3X\Card Drivers . maby can help ........... |
11-28-2009, 23:58 | #3 (permalink) |
Member: 1152345 Status: Offline Thanks Meter: 9 | All drivers installed now, but when I run Qualcomm tool and chose model F480 then click search, it says searching Samsung Qualcomm interface no found. I tried 2 cables already, it's doing same thing. Please help |
11-29-2009, 11:52 | #4 (permalink) |
Member: 878925 Status: Offline Sonork: ;-) Thanks Meter: 786 | Mobile need to be ON and in qualcom mode enter thes code in your phone ( *#782872# and press ok ) now connect your phone to pc and install your phone qualcom driver you can find the driver z3x folder than run Qualcomm tool , and make your job .. |
11-29-2009, 13:23 | #6 (permalink) |
Member: 1152345 Status: Offline Thanks Meter: 9 | All drivers installed ok, of course i turn on the phone and use RJ45 cable, the phone is locked by user password, the user forgets the password, so I can't do anything to enter the code above. I try to master reset or flash the phone, but the phone not communicated with the box through Qualcomm tool. Any other solutoin? |
11-29-2009, 15:34 | #8 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
11-29-2009, 17:00 | #9 (permalink) |
Member: 1152345 Status: Offline Thanks Meter: 9 | I'm using z3x box to reset the user passcode, the user forgets the passcode how can I get into the phone to switch to flash mode? I use RJ45 cable to connect the phone to the box for doing its job to reset the passcode, if you connect to pc how can you reset the passcode? it's impossible. |
11-29-2009, 18:56 | #10 (permalink) | |
NEW Z3X Box drivers ver. 2.04.16 | Mantikor | Z3X-Team Products | 29 | 01-30-2017 18:56 |
z3x box drivers | sklab786 | Z3X-Team Products | 7 | 12-26-2015 11:57 |
Z3x Box Driver Problem | suli_3011 | Z3X-Team Products | 12 | 09-04-2011 13:33 |
z3x box driver | wonderfulgg | Z3X-Team Products | 2 | 11-30-2009 12:29 |
ı need active z3x card and chian software | osom | Z3X-Team Products | 16 | 09-01-2008 09:21 |
