08-23-2017, 15:15 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: PAKISTAN
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Z3x card error Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. (Note, that the cert file for this model is unique. You can write cert, wich is readed from this device exactly.) Operation: Read CERT Selected model: SM-J710F Software version: 28.6 Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZWDPAK Phone version: J710FXXU2AQB2 PDA version: J710FXXU2AQB3 CSC version: J710FOJV2AQB2 CSC country code: PAKISTAN CSC sales code: PAK HW version: MP 0.300 Phone SN: RF8H61HNQJK Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-02-01 RF cal date: 20160615 IMEI: Checking Super user right... true Card error (32043) Done with Samsung Tool PRO v.28.6 Z3X LATEST VER SAME ERROR |
