Old 12-28-2019, 21:05   #31 (permalink)
Member: 2194348
Thanks Meter: 52
i have the same problem ; just use other tool
Old 12-29-2019, 09:49   #32 (permalink)
Member: 2176646
Z3x Freez Adb
i have the same problem ; I'm sure the strong z3x team will fix this
Old 12-30-2019, 01:07   #33 (permalink)
kachman's Avatar
Member: 272581
Thanks Meter: 118
this problem has been there for the past 3 or 4 Z3x updates. Sometimes using a different cable helps me. The only solution that always work is using an older version than 38.4.
Also try to minimize z3x window, then connect phone, restore the window and then try to see if the phone is detected in z3x
Old 12-31-2019, 10:36   #34 (permalink)
Member: 2938943
Thanks Meter: 13
Me too sometimes hangs i do not know why they dont solve this problem.
Old 01-07-2020, 15:47   #35 (permalink)
-=MR_Gsm=-'s Avatar
Member: 762055
Sonork: -=664053=-
Thanks Meter: 778
hang on adb selected....
Originally Posted by elmowaldo View Post
simply go C:\Users\username\.android and delete all the keys..turn off usb debugging and turn it on again and go the adb tab and select adb..it worked for me
adbkey+adbkey.pub
worked for me 100/100
BR,
-=MR_Gsm=-
The Following User Says Thank You to -=MR_Gsm=- For This Useful Post:
Old 01-15-2020, 14:20   #36 (permalink)
mintu4200's Avatar
Member: 2120393
Thanks Meter: 238
Adbkey+adbkey.pub
br,
-=mr_gsm=-
not working for me >>>>>>>>>>>>
i have also same problem with z3x 39.0 version
Old 01-15-2020, 14:34   #37 (permalink)
-=MR_Gsm=-'s Avatar
Member: 762055
Sonork: -=664053=-
Thanks Meter: 778
worked for me
adbkey+adbkey.pub
worked for me
BR,
-=MR_Gsm=-
Old 03-02-2020, 10:59   #38 (permalink)
Member: 2228162
Sonork: 23243564rtrwe
Thanks Meter: 31
same problem here deleted adbkeys still same
Old 03-04-2020, 14:08   #39 (permalink)
-=MR_Gsm=-'s Avatar
Member: 762055
Sonork: -=664053=-
Thanks Meter: 778
You can try
New update
BR,
-=MR_Gsm=-
Old 03-04-2020, 15:14   #40 (permalink)
Member: 2803071
Thanks Meter: 46
after deleting keys run command prompt as an administrator and type adb start-server
The Following User Says Thank You to elmowaldo For This Useful Post:
Old 05-10-2020, 08:30   #41 (permalink)
Member: 2945097
Hi guys at least I found the problem I have G610f the same problem freezing the z3x I try on two pc but same problem after that I found that the twrp is installed I hard reset but the same problem I flashed the phone with z3x and now it work 100%
Old 05-14-2020, 17:05   #42 (permalink)
Member: 1943302
Thanks Meter: 5
same problem
with 2 pc
Old 06-05-2020, 08:49   #43 (permalink)
Member: 2123463
Sonork: 100.1652545
Thanks Meter: 29
Sir old versions aare ok
in new version of samsung tool pro
adb with rooted device freezes
not rooted devices ok with that
any solution?????
Old 06-06-2020, 19:39   #44 (permalink)
Member: 110950
Thanks Meter: 29
I have same problem . Can any one help us ?
Old 06-07-2020, 07:29   #45 (permalink)
Registered User
Member: 1669709
Sonork: 1654655
Thanks Meter: 163
not working for me
freeeeeeez
Page generated in 0.24490 seconds with 8 queries
