S6 Sprint G920P 7.0 Nougat FRP removing Hello guys! This is how to FRP Googgle Account Unlock Removal using the Z3X on a Samsung Galaxy S6 for Sprint SM-G920P with G920PVPU4DQC7 7.0 Nougat Android Version (For Bigginers/Newbies): 1. First Download and unzip these files: " FRP_ENG_SBOOT_G920PVPU4API2.zip " and "G920PVPS4CPI3 6.0.1" 2. Downgrade your G920PVPU4DQC7 7.0 Nougat to G920PVPS4CPI3 Marshmallows 6.0.1: Put the phone into "Download Mode" and flash the phone with G920PVPS4CPI3_SPT4CPI3_SPR_Sprint_USA_6.0.1 using ODIN "AP" slot. 3. After the downgrade and to activate the ADB on your phone, you need to put the phone back into "Download Mode" again. Flash the "ENG_SBOOT_G920PVPU4API2.tar" using ODIN "AP" or "BL" slot. The phone will get stock on the initial "Samsung S6" screen. 4. Put the phone into "Download Mode" again but this time, connect the phone to your computer. Open your Z3X BOX Samsung Tool PRO V28.1 software, Select the G920P Model, Go to the "Backup" tap and select the "COM" port. Then go to "Unlock" tap and click on the "Reset FRP/React/EE" and wait until the Z3X Box does its magic :D : Operation: Reset FRP/React/EE Selected model: SM-G920P Software version: 28.1 Searching Samsung USB Flash interface... COM10 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.1 5. The phone will get stock again in the same "Samsung S6" logo screen. So, put the phone into "Download Mode" again and this time flash the "STOCK_SBOOT_G920PVPS4CPI3.tar" file included in the folder using ODIN "AP" or "BL" slot. 6. The phone should get to the home screen (If not, flash the whole G920PVPS4CPI3_SPT4CPI3_SPR_Sprint_USA_6.0.1 firmware again). When the phone goes to home screen, go to "Settings", then to "Backup and Reset" and then press "Factory Reset". The phone will factory reset itself and the FRP lock should be removed. 7. To upgrade back to G920PVPU4DQC7 7.0 Nougat, download and unzip the G920PVPU4DQC7 7.0 Nougat.zip . Put the phone into "Download Mode", and flash the G920PVPU4DQC7 file using ODIN "AP" slot. After the flashing, the phone should be able to boot to Nougat 7.0 CLEAN and CLEAR! PLEASE DO NOT FORGET TO CLICK ON THE THANKS BUTTON!! ======================>>> |
Anyone else having the same problem? UNLOCK INSTRUCTIONS: Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G920P Software version: 24.9 Searching Samsung USB Flash Interface... detected COM68 Setup connection... OK Reading PIT from phone... error Done with Samsung Tool PRO v.28.1 |
Sprint Quote:
n920pvpu3apj1 or lattes please.... |
can we able to downgrade it? |
thanks We can do without downgrade .. After we break the account with z3x we install a file stock sboot for the same flash on the device before the flash |
I am not understanding from any angle these conversations/instructions. I have a Sprint SM-G920p S6 phone and I also have my z3x but I cant seem to follow you all instructions correctly. I placed the sboot. file in Odin at BL and the Home firmware at AP but it is still saying fail. Is this the way to do it? I am on running G920PVPS4DQE2_G920PSPT4DQE2_SPR and tested with G920PVPU3BOJ7 and SBOOT_G920P_OJ7 downgrade. I have FRP and phone need to be unlocked. Help with z3x and operations!!!!!!! |
Flash it with this file FRP_ENG_SBOOT_G920PVPU4API2 |
Thank you so much, it work perfect! |
thank you, it work perfect!! |
Thanks GalaxyVibe for you info. I did a little more research before now and got it working. Keep up the good work! |
Thank you very much.. It work perfectly. |
its magic) Thanks :) It work perfectly. |
alternate solution alternate solution for revision 4 build only! (also works for unlock sim) - flash https://drive.google.com/open?id=1Yn...3edvv_qEO1T-02 - remove FRP/unlock SIM via box of choice - factory reset if doing FRP - flash stock boot.img back to phone - profit. |
Here is direct link : https://mega.nz/#!a5YGDAaT!ah0oqcaBq...9d6BatYStX2cE;) |
