Old 05-10-2017, 04:14   #1 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 615
Z3X FRP Google Account Unlock Removal:Galaxy S6 Sprint G920P G920PVPU4DQC7 7.0 Nougat
Hello guys! This is how to FRP Googgle Account Unlock Removal using the Z3X on a Samsung Galaxy S6 for Sprint SM-G920P with G920PVPU4DQC7 7.0 Nougat Android Version (For Bigginers/Newbies):
1. First Download and unzip these files: " FRP_ENG_SBOOT_G920PVPU4API2.zip " and "G920PVPS4CPI3 6.0.1"
2. Downgrade your G920PVPU4DQC7 7.0 Nougat to G920PVPS4CPI3 Marshmallows 6.0.1: Put the phone into "Download Mode" and flash the phone with G920PVPS4CPI3_SPT4CPI3_SPR_Sprint_USA_6.0.1 using ODIN "AP" slot.
3. After the downgrade and to activate the ADB on your phone, you need to put the phone back into "Download Mode" again. Flash the "ENG_SBOOT_G920PVPU4API2.tar" using ODIN "AP" or "BL" slot. The phone will get stock on the initial "Samsung S6" screen.
4. Put the phone into "Download Mode" again but this time, connect the phone to your computer. Open your Z3X BOX Samsung Tool PRO V28.1 software, Select the G920P Model, Go to the "Backup" tap and select the "COM" port. Then go to "Unlock" tap and click on the "Reset FRP/React/EE"
and wait until the Z3X Box does its magic :
Operation: Reset FRP/React/EE
Selected model: SM-G920P
Software version: 28.1
Searching Samsung USB Flash interface... COM10 detected
Setup connection... Ok
Reading PIT from phone... Ok
Searching FRP lock... Ok
Erasing FRP lock... Ok
Reset done
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.28.1
5. The phone will get stock again in the same "Samsung S6" logo screen. So, put the phone into "Download Mode" again and this time flash the "STOCK_SBOOT_G920PVPS4CPI3.tar" file included in the folder using ODIN "AP" or "BL" slot.
6. The phone should get to the home screen (If not, flash the whole G920PVPS4CPI3_SPT4CPI3_SPR_Sprint_USA_6.0.1 firmware again). When the phone goes to home screen, go to "Settings", then to "Backup and Reset" and then press "Factory Reset". The phone will factory reset itself and the FRP lock should be removed.
7. To upgrade back to G920PVPU4DQC7 7.0 Nougat, download and unzip the G920PVPU4DQC7 7.0 Nougat.zip . Put the phone into "Download Mode", and flash the G920PVPU4DQC7 file using ODIN "AP" slot. After the flashing, the phone should be able to boot to Nougat 7.0 CLEAN and CLEAR!
PLEASE DO NOT FORGET TO CLICK ON THE THANKS BUTTON!! ======================>>>
The Following 44 Users Say Thank You to GalaxyVibe For This Useful Post:
Old 05-20-2017, 00:09   #2 (permalink)
Member: 157223
Thanks Meter: 3
Anyone else having the same problem?
UNLOCK INSTRUCTIONS:
Domestic Unlock:
1. Power on the phone.
2. Enable 'USB debugging' in 'Settings'-'Developer options',
tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock Domestic' button.
To reset Google account activation or Samsung reactivation lock:
1. Power on phone in download mode (turn off phone, press vol.down + home + power).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Software version: 24.9
Searching Samsung USB Flash Interface... detected COM68
Setup connection... OK
Reading PIT from phone... error
The Following User Says Thank You to mattrojan For This Useful Post:
Old 05-20-2017, 00:34   #3 (permalink)
Member: 2433136
Thanks Meter: 245
Sprint
Originally Posted by galaxyvibe View Post
hello guys! This is how to frp googgle account unlock removal using the z3x on a samsung galaxy s6 for sprint sm-g920p with g920pvpu4dqc7 7.0 nougat android version (for bigginers/newbies):
1. First download and unzip these files: " frp_eng_sboot_g920pvpu4api2.zip " and "g920pvps4cpi3 6.0.1"
2. Downgrade your g920pvpu4dqc7 7.0 nougat to g920pvps4cpi3 marshmallows 6.0.1: Put the phone into "download mode" and flash the phone with g920pvps4cpi3_spt4cpi3_spr_sprint_usa_6.0.1 using odin "ap" slot.
3. After the downgrade and to activate the adb on your phone, you need to put the phone back into "download mode" again. Flash the "eng_sboot_g920pvpu4api2.tar" using odin "ap" or "bl" slot. The phone will get stock on the initial "samsung s6" screen.
4. Put the phone into "download mode" again but this time, connect the phone to your computer. Open your z3x box samsung tool pro v28.1 software, select the g920p model, go to the "backup" tap and select the "com" port. Then go to "unlock" tap and click on the "reset frp/react/ee"
and wait until the z3x box does its magic :d :
Operation: Reset frp/react/ee
selected model: Sm-g920p
software version: 28.1
searching samsung usb flash interface... Com10 detected
setup connection... Ok
reading pit from phone... Ok
searching frp lock... Ok
erasing frp lock... Ok
reset done
for complete reset frp, goto 'backup and reset' and make 'factory data reset'
done with samsung tool pro v.28.1
5. The phone will get stock again in the same "samsung s6" logo screen. So, put the phone into "download mode" again and this time flash the "stock_sboot_g920pvps4cpi3.tar" file included in the folder using odin "ap" or "bl" slot.
6. The phone should get to the home screen (if not, flash the whole g920pvps4cpi3_spt4cpi3_spr_sprint_usa_6.0.1 firmware again). When the phone goes to home screen, go to "settings", then to "backup and reset" and then press "factory reset". The phone will factory reset itself and the frp lock should be removed.
7. To upgrade back to g920pvpu4dqc7 7.0 nougat, download and unzip the g920pvpu4dqc7 7.0 nougat.zip . Put the phone into "download mode", and flash the g920pvpu4dqc7 file using odin "ap" slot. After the flashing, the phone should be able to boot to nougat 7.0 clean and clear!
please do not forget to click on the thanks button!! ======================>>>
hi, i have sprint note5 need combination file
n920pvpu3apj1 or lattes please....
The Following User Says Thank You to holasamsung For This Useful Post:
Old 06-29-2017, 19:54   #4 (permalink)
Member: 2721132
Thanks Meter: 2
can we able to downgrade it?
Old 07-03-2017, 18:01   #5 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 615
Yes, you can downgrade your G920PVPU4DQC7 7.0 Nougat to G920PVPS4CPI3 Marshmallows 6.0.1
Old 07-13-2017, 19:19   #6 (permalink)
Member: 2733214
thanks We can do without downgrade ..
After we break the account with z3x we install a file stock sboot for the same flash on the device before the flash
Old 07-30-2017, 22:18   #7 (permalink)
Member: 2694361
I am not understanding from any angle these conversations/instructions. I have a Sprint SM-G920p S6 phone and I also have my z3x but I cant seem to follow you all instructions correctly.
I placed the sboot. file in Odin at BL and the Home firmware at AP but it is still saying fail. Is this the way to do it? I am on running G920PVPS4DQE2_G920PSPT4DQE2_SPR and tested with G920PVPU3BOJ7 and SBOOT_G920P_OJ7 downgrade. I have FRP and phone need to be unlocked. Help with z3x and operations!!!!!!!
Old 08-26-2017, 16:05   #8 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 615
It is always recommended to downgrade to the lowest binary possible before doing any repairs in the phone because of the security patches on the laterest firmwares.
What you are doing wrong is that your current firmware binary is 4 (G920PVPS4DQE2) and you are running the binary 3 Sboot file (G920PVPU3BOJ7). You need to get the binary 4 Sboot in other for the proceedure to work.
Flash it with this file FRP_ENG_SBOOT_G920PVPU4API2
The Following User Says Thank You to GalaxyVibe For This Useful Post:
Old 09-11-2017, 11:15   #9 (permalink)
Member: 2722627
Thank you so much, it work perfect!
Old 09-11-2017, 11:45   #10 (permalink)
Member: 2722627
thank you, it work perfect!!
Old 09-13-2017, 02:16   #11 (permalink)
Member: 2694361
Thanks GalaxyVibe for you info. I did a little more research before now and got it working. Keep up the good work!
Old 10-06-2017, 03:00   #12 (permalink)
Member: 162707
Thanks Meter: 54
Thank you very much.. It work perfectly.
Old 11-22-2017, 23:42   #13 (permalink)
Member: 2407804
its magic) Thanks It work perfectly.
Old 11-25-2017, 04:00   #14 (permalink)
Member: 2592628
Thanks Meter: 90
alternate solution
alternate solution for revision 4 build only! (also works for unlock sim)
- flash https://drive.google.com/open?id=1Yn...3edvv_qEO1T-02
- remove FRP/unlock SIM via box of choice
- factory reset if doing FRP
- flash stock boot.img back to phone
- profit.
Page generated in 0.46194 seconds with 7 queries
