12-21-2010, 18:34 | #1 (permalink) |
Freak Poster Join Date: May 2006 Age: 41
Member: 276850 Status: Offline Thanks Meter: 717 | Wave 723 not detected i tried to unlock my samsung s7230e but phone is not detected by software i tried all port but nothing i flashed it 3 times but some problem phone version now is: s723exejj6 when i type *#197328640# -> common -> diag config (Data Service config not exist) i got [1]UART BUAD RATE -- 115K[*] [2]UART BUAD RATE -- 921K [ ] [3]Wincomm tool[*] [4]MA [ ] [5]MTT [ ] [6]Wincomm & Brcm Tool - ON [ ] [7]Wincomm & Brcm Tool - OFF[*] [8]LOGGING MODE - UART [ ] [9]LOGGING MODE - USB [ ] [10] AT Command MODE - ON[*] what i should do ? |
12-21-2010, 18:37 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
The Following User Says Thank You to blang For This Useful Post: |
12-21-2010, 18:50 | #3 (permalink) |
Member: 276850 Status: Offline Thanks Meter: 717 | Phone unlocked thanks Searching Samsung USB Modem... detected (COM26) Reading Phone Info... OK Model: GT-S7230E Factory SW: S723EBVJJ1_FTMJJ1 CountryCode: FTM UniqueNumber: 74700000555681 MemoryPhone: KAT00M020A(S7230) SW: HedgePlatformBRCM2156_SI1.2.9.1_V06:umts22WedOct20 16:56:042010 IMEI: 3540670415xxxx/x Reading SysInfo... OK Searching server... OK Calculating codes... OK (time - 00:00:36) Freeze code: 94624752 NET lock: #7465625*638*31460704# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# SIM lock: #7465625*746*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.9 |
12-21-2010, 19:04 | #4 (permalink) | |
12-22-2010, 09:34 | #6 (permalink) |
Freak Poster Join Date: Sep 2004
Member: 82815 Status: Offline Thanks Meter: 160 | Searching Samsung USB Modem... detected (COM77) Reading Phone Info... OK Model: GT-S7230E Factory SW: S723EAGJJ2_BOGJJ2 CountryCode: BOG UniqueNumber: 74240001853857 MemoryPhone: KAT00M020A(S7230) SW: HedgePlatformBRCM2156_SI1.2.9.1_V06:umts22TueOct51 2:02:052010 IMEI: 35406704130102/0 Reading SysInfo... OK Searching server... OK Calculating codes... OK (time - 00:00:44) Freeze code: 51529139 NET lock: #7465625*638*41703949# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# SIM lock: #7465625*746*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.9 |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
