12-05-2016, 21:30 | #1 (permalink) |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | Z3X Samsung Galaxy Note 5 AT&T SM-N920A IMEI REpair Need Root! Help Please! |
12-05-2016, 22:15 | #5 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | bro gc prokey Quote:
http://forum.gsmhosting.com/vbb/f922...gcpro-2138617/ | |
The Following 2 Users Say Thank You to ghacks For This Useful Post: |
12-05-2016, 23:56 | #7 (permalink) | |
Member: 2577670 Status: Offline Thanks Meter: 883 | I found the Combination firmware file that will work for N920AUCS3BPH4 (Thanks carl_es): Quote: | |
The Following 2 Users Say Thank You to GalaxyVibe For This Useful Post: |
12-06-2016, 01:39 | #8 (permalink) |
Member: 2577670 Status: Offline Thanks Meter: 883 | Repair Done :-) Operation: Patch Certificate Selected model: SM-N920A Software version: 27.3 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-N920A Android version: 5.1.1 Product code: SM-N920AZKEATT Phone version: N920AUCU3APH1 PDA version: FA51_N920AUCU3APH1 CSC version: CSC country code: CSC sales code: HW version: REV1.0 Phone SN: R38G90212BL Modem board: SHANNON333 RF cal date: 20150902 IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading modem OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.27.3 |
The Following User Says Thank You to GalaxyVibe For This Useful Post: |
12-06-2016, 03:43 | #9 (permalink) |
Member: 2577670 Status: Offline Thanks Meter: 883 | I am having a problem with this repair. I installed the Combination firmware in order to root the phone. I did the repair and patched certificate on the Combination Firmware. the phone picks up signal and all. But when I install the original firmware, the phone IMEI becomes "NEG" and the phone does not connect to the network with "Emergency Calls ONLY". Any suggestions?? |
12-06-2016, 04:16 | #10 (permalink) |
Member: 2577670 Status: Offline Thanks Meter: 883 | I upgraded only the modem and kept running the Combination firmware. I tried patching the modem again and it says "RUNNING ZtOOL, PLEASE WAIT.. ERROR (7.7.8) Current versin can not be patched". Suggestions?? |
12-06-2016, 06:32 | #12 (permalink) |
Member: 2577670 Status: Offline Thanks Meter: 883 | I solved my problem. Instead of writing the IMEI myself and patching it, I when to the "Repair" tab and clicked on the "Write Cert". I picked the right file and the phone was repaired and picked up signal even after original firmware was restore. PS: If you do not have a "Cert File" for a N920A, you can write your own patch it, and when you are doing the original firmware restoration "DO NOT UPGRADE THE MODEM" so the phone can still work even after the original firmare restoration. Keep in mind that the phone is going to loose the patch if the modem is upgraded or changed in any way. If this was helpfull for you, PLEASE CLICK THE THANK YOU BUTTON! :-)) |
