12-21-2015, 12:59 | #82 (permalink) |
Freak Poster Join Date: Mar 2007 Location: In the skies
Member: 460298 Status: Offline Thanks Meter: 32 | I'm waiting for unlock Samsung AU-KDDI models like SCL23(SM-G900J),SCL24(SM-N915J)... but it's still not unlocked. SCL23 can be active DIAG, show unlock done, but still not unlock SCL24 can't active DIAG, use C3303 cable to enable *#0808#, after that, press unlock button, everything is ok on software but phone still not unlock. |
12-21-2015, 13:01 | #83 (permalink) |
Freak Poster Join Date: Oct 2014 Location: bharat Age: 35
Member: 2276401 Status: Offline Thanks Meter: 98 | samsung s6312 remove **** app done by new update Selected model: GT-S6312 Software version: 23.8 File analysis... OK Total file size: 0x3CAF1A8C (970 Mb) Searching USB Flash Interface... detected COM93 Setup connection... OK Reading PIT from phone... OK Sending oemsbl... OK Sending appsbl... OK Sending qcsbl.mbn... OK Sending qcsblhd_cfgdata.mbn... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending userdata.img.ext4... OK Sending persist.img.ext4... OK Sending fat.bin... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Flashing done (time - 00:11:01) Done with Samsung Tool PRO v.23.8 |
12-21-2015, 13:20 | #85 (permalink) |
No Life Poster Join Date: Jan 2008 Location: ETHIOPIA
Member: 688223 Status: Offline Sonork: 1000.1603261 Thanks Meter: 143 | new update not work Operation: Unlock Selected model: SM-N910T Selected port: COM236 SAMSUNG Mobile USB Serial Port Software version: 23.8 Reading phone info... Reading IMEI... OK IMEI: 356095066684515 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.23.8 phone still locked and ask code |
12-21-2015, 13:48 | #87 (permalink) |
Junior Member Join Date: Mar 2012 Location: Belarus/ Minsk
Member: 1736186 Status: Offline Thanks Meter: 23 | Samsung J500FN Unlock Done UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', enable 'USB debugging' in 'Settings'-'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J500FN Selected port: COM31 SAMSUNG Mobile USB Serial Port Software version: 23.8 Reading phone info... Reading IMEI... OK IMEI: 3552690***** Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.23.8 thx z3x team) |
12-21-2015, 14:34 | #89 (permalink) |
Freak Poster Join Date: Jun 2010 Location: ON Maind
Member: 1326581 Status: Offline Sonork: (((NAEEM))) Thanks Meter: 52 | FAKE UNLOCK Z3X WHAT IS THIS MR BLANG Selected model: I8200N Selected port: COM332 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM23 Reading phone info... Model: GT-I8200N Country code: VOD Cal date: ªU Factory SW: I8200NXXUANJ2 Unique number: C Memory phone: ªU Software version: I8200NXXUANJ2/I8200NXXUANJ2/I8200NVFGANJ2 IMEI: 355583067197026 Product code: Done with Samsung Tool v.19.1 Selected model: I8200N Selected port: COM332 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I8200N Android version: 4.2.2 Product code: GT-I8200RWNVOD Phone version: I8200NXXUANJ2 PDA version: I8200NXXUANJ2 CSC version: I8200NVFGANJ2 IMEI: 355583067197026 Phone S/N: RF1FB0ST5ZF Checking Super user right... true Bypass MSL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.19.1 Done with Samsung Tool v.19.1 |
