11-20-2012, 14:19 | #1 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1836898 Status: Offline Thanks Meter: 0 | Z3X "Searching Samsung modem... not found" But it wont find my phone! In "X3X Samsung tool v13.3" it wont find my Samsung galaxy S3. It says: Log: "Searching Samsung modem... not found" or "Phone not found" It says that all the time. Do you know the problem solver? Thanks |
11-20-2012, 14:48 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,549 | Quote:
The Following User Says Thank You to blang For This Useful Post: |
11-20-2012, 14:58 | #3 (permalink) |
Member: 1836898 Status: Offline Thanks Meter: 0 | I have installed all the drivers.. when i plug in the phone directly to the computer it gets found. But when i put it in z3x box it says device unknown in windows 7. But i have tried putting different drivers on the "unknown device" such as Samsung modem and so on.. but nothing works. I have tried now for over 7 hours |
11-20-2012, 15:22 | #5 (permalink) | |
Member: 1836898 Status: Offline Thanks Meter: 0 | Quote:
No not unlocking, more like imei modifications that i am out after. | |
11-20-2012, 15:39 | #7 (permalink) |
Member: 1836898 Status: Offline Thanks Meter: 0 | yes now you can repair imei i9300 with original imei or not original imei: work network yes At first I will re-process change imie .this time type imie as you like original or not-original ( If you had written the original will not need to patch in the end the subject. but sometimes the network does not work with original imie) 1. Select Model i9100 and Select port 2. The first arrived USB in Mobile. on repair choose com press pepair 4. Type imie no. press ok 5. After Rebooting phone .... remove the USB cable. Put cable RJ45 http://forum.gsmhosting.com/vbb/f453...netwo-1556722/ This is what i want to do! |
03-15-2013, 01:34 | #9 (permalink) |
Registered User Join Date: Nov 2006 Location: Australia Age: 66
Member: 382531 Status: Offline Thanks Meter: 2 | Fixed it can you sway how you fixed it I've been trying for awhile Rooted SU etc. Always getting modem not found. USB modem on. USB modem off still the same. I have the UART cable still not getting picked up Probably motherboard issue. I have Repaired IMEI number before on S3 9300 this one is 9305 |
08-25-2015, 16:54 | #11 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2446640 Status: Offline Thanks Meter: 0 | Samsung modem not found Hi I have just bought z3x box. But I am facing problem when flashing mobile. I am facing modem/phone not found error while doing flash. please find the below logs. Selected model: E1200I Selected port: COM3 USB Serial Port Selected port speed: 921600 Searching Samsung modem... not found Done with Samsung Tool v.19.0 Selected model: E1200I Selected port: COM3 USB Serial Port Selected port speed: 921600 Searching Samsung modem... not found Done with Samsung Tool v.19.0 Selected model: E1200I Selected port: COM3 USB Serial Port Selected port speed: 921600 Searching Samsung modem... not found Done with Samsung Tool v.19.0 Selected model: E1200I Selected port: COM3 USB Serial Port Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.19.0 please help to resolve this.I am new to z3x box. |
06-15-2016, 15:21 | #13 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2431187 Status: Offline Thanks Meter: 0 | Hi I have just bought z3x box. But I am facing problem when flashing mobile. I am facing modem/phone not found error while doing flash. please find the below logs. Selected model: S7262 Selected port: Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.19.1 But in Device Manager in My Computer There is Samsung Mobile Usb Modem Please Solve this problem |
