09-10-2013, 16:19 | #1 (permalink) |
Insane Poster Join Date: Dec 2011
Member: 1708930 Status: Offline Thanks Meter: 3 | Z3x team help me about samsung c3262... here is log... Selected model: C3262 Selected port: COM11 Z3X BOX Serial Port Selected port speed: 921600 Reconnect battery and connect phone to USB cable Phone detected Opening device... OK Checking device descriptions... OK Device description: 04CC 0409 Checking config descriptor... OK Reading OTP register... OK OTP register: 473E8100 Reading product ID... OK Product ID: 000195A918DA7120 Reading SCROM version... OK SCROM version: 0x31 Chipset version: 0x48 Sending loader... OK Start loader... OK Waiting phone... OK Opening device... OK Checking device descriptions... OK Device description: 04CC 0409 Checking config descriptor... OK Reading loader version... OK Loader version: 7.5.16 Init Flash... OK Loading flash info... OK Configure Flash... OK Erase memory for external loader... OK Sending external loader... OK Start external loader... OK Waiting phone... OK Opening device... OK Checking device descriptions... OK Device description: 04CC 0409 Checking config descriptor... OK Reading loader version... OK Loader version: 7.5.16 Init Flash... OK Load flash info... OK Configure Flash... OK OK Loading PTT file... OK Reading first block... OK Erasing first block... OK Flashing first block... OK Init bad block... OK Erasing IMAGE... OK Erasing LCDACT... OK Erasing DATA_RW... OK Erasing DSP... OK Erasing PAGE... OK Erasing MAIN... OK Erasing a... OK Erasing b... OK Erasing c... OK Erasing d... OK Erasing OTPW... OK Writing IMAGE... OK Writing LCDACT... OK Writing DATA_RW... OK Writing DSP... OK Writing PAGE... OK Writing MAIN... OK Writing a... error Done with Samsung Tool v.14.1 Done with Samsung Tool v.14.1 i think i did not select firmwares kindly help me otherwise tell me by which firmware should i flash??? |
09-10-2013, 16:21 | #2 (permalink) |
Member: 1708930 Status: Offline Thanks Meter: 3 | i have a samsung c3262... its hanging on samsung logo, i tried to flash but like this error showing here is log... Selected model: C3262 Selected port: COM11 Z3X BOX Serial Port Selected port speed: 921600 Reconnect battery and connect phone to USB cable Phone detected Opening device... OK Checking device descriptions... OK Device description: 04CC 0409 Checking config descriptor... OK Reading OTP register... OK OTP register: 473E8100 Reading product ID... OK Product ID: 000195A918DA7120 Reading SCROM version... OK SCROM version: 0x31 Chipset version: 0x48 Sending loader... OK Start loader... OK Waiting phone... OK Opening device... OK Checking device descriptions... OK Device description: 04CC 0409 Checking config descriptor... OK Reading loader version... OK Loader version: 7.5.16 Init Flash... OK Loading flash info... OK Configure Flash... OK Erase memory for external loader... OK Sending external loader... OK Start external loader... OK Waiting phone... OK Opening device... OK Checking device descriptions... OK Device description: 04CC 0409 Checking config descriptor... OK Reading loader version... OK Loader version: 7.5.16 Init Flash... OK Load flash info... OK Configure Flash... OK OK Loading PTT file... OK Reading first block... OK Erasing first block... OK Flashing first block... OK Init bad block... OK Erasing IMAGE... OK Erasing LCDACT... OK Erasing DATA_RW... OK Erasing DSP... OK Erasing PAGE... OK Erasing MAIN... OK Erasing a... OK Erasing b... OK Erasing c... OK Erasing d... OK Erasing OTPW... OK Writing IMAGE... OK Writing LCDACT... OK Writing DATA_RW... OK Writing DSP... OK Writing PAGE... OK Writing MAIN... OK Writing a... error Done with Samsung Tool v.14.1 Done with Samsung Tool v.14.1 i think i did not select firmwares correct.. kindly help me otherwise tell me by which firmware should i flash??? |
09-10-2013, 16:28 | #3 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Brother Every Z3X User Feel This Problem , I Hope Next Update Fixed It At This Time Use Flasher I Hope You Will See Flash Done Tested By Me |
09-10-2013, 16:33 | #4 (permalink) |
Insane Poster Join Date: Jun 2009
Member: 1060642 Status: Offline Thanks Meter: 17 | use this link http://forum.gsmhosting.com/vbb/f200...-here-1597131/ |
