12-16-2016, 05:33 | #1 (permalink) |
Insane Poster Join Date: Oct 2012
Member: 1825305 Status: Offline Thanks Meter: 22 | Z3x write cert error Exception: Cannot open file ''. The filename, directory name BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-G925T Software version: 27.5 Waiting ADB device... Ok Reading phone info... Model: SM-G925T Android version: 6.0.1 Product code: Phone version: G925TUVU5EPK5 PDA version: G925TUVU5EPK5 CSC version: G925TTMB5EPK5 CSC country code: USA CSC sales code: TMB HW version: Phone SN: R58G624AARF Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Exception: Cannot open file ''. The filename, directory name, or volume label syntax is incorrect Done with Samsung Tool PRO v.27.5 |
12-16-2016, 07:25 | #2 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: india Age: 43
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | Quote:
Code: Chip name: EXYNOS7420 Modem board: SHANNON333 | |
