08-15-2015, 04:42 | #1 (permalink) |
Freak Poster Join Date: Jun 2015 Age: 33
Member: 2418095 Status: Offline Thanks Meter: 125 | Z3xbox 22.2 PRO version Exynos chip how to select ADB device I tried to select port form the image but there isn`t one for me to choose. Now I can neither read nor write CERT. |
08-15-2015, 05:49 | #2 (permalink) |
Member: 2418095 Status: Offline Thanks Meter: 125 | What should I do, how to form a port? 22.0 version is not required to do so.. Why do I try to fix the phone after the update will get the tip:"ADB device not selected"????????????????????????????????????????? ????? |
The Following User Says Thank You to TaiChi gossip For This Useful Post: |
08-15-2015, 06:25 | #3 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | You must Enable USB Debugging & Look at Device Manager if need a drivers installation. |
The Following User Says Thank You to xerraco For This Useful Post: |
08-15-2015, 06:51 | #5 (permalink) |
Member: 890926 Status: Offline Thanks Meter: 2,053 | What are you trying to do with that N5100,phone *#0808# and choose "MTP + ADB" then need to choose Samsung Diagnostic port if Repairing or Unlocking & others. |
08-15-2015, 07:02 | #6 (permalink) | |
Member: 2418095 Status: Offline Thanks Meter: 125 | Quote:
I've tried to do that, *#0808# MTP + ADB Still can't display port, I can now return to the 22 .0 version. This version is all right! | |
08-15-2015, 07:10 | #7 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | I will check now on my i9300, may be small bug after adding new function. |
The Following User Says Thank You to blang For This Useful Post: |
08-16-2015, 04:21 | #9 (permalink) |
Member: 2418095 Status: Offline Thanks Meter: 125 | z3xPRO22.2 Still the result.. Cannot display port ------------------------------------------------------------------------ Z3XPRO22.0 I also asked my fellow Chinese. They are the same problem... If you go back to the previous version, you won't have this problem. |
08-16-2015, 04:27 | #10 (permalink) | |
Please look at it. I can`t operate any phone with a Exynos core | |
08-16-2015, 10:53 | #11 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
can you give me link for any virtual wmware image Chinese windows or Chinese windows installation, so then we will check problem. | |
08-16-2015, 13:24 | #12 (permalink) | |
Freak Poster Join Date: May 2007 Location: Mumbai, India Age: 41
Member: 513417 Status: Offline Thanks Meter: 87 | yes its bug must fix it Quote:
then i install old then it was fine so plz fix it this prob if u want I can send u screenshot of log detail | |
08-16-2015, 14:06 | #13 (permalink) |
Member: 2418095 Status: Offline Thanks Meter: 125 | Thank the team! My problem is solved, maybe I was too stupid. I cleaned up the Reset ADB got the job... Unfortunately, I need to run Reset ADB every time. Want to be able to join Reset ADB in the next update. |
