08-21-2008, 07:48 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Philippines Age: 45
Member: 164332 Status: Offline Thanks Meter: 40 | BB5 IMEI 12345610654321_.ask Help GSM Father.. I have trouble writing RPL from GSM father.. Here logs Info. before writing RPL FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 04wk47_m_v14 09-02-06 RM-36 (c) Nokia. PCI version: RFIC version: 150a160f DSP version: pb04w47v23 Retu version: 32 Tahvo version: 52 Production serial number: Product code: Module code: Basic production code: Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 12345610654321? IMEI spare to net: 1A 32 54 16 60 45 23 01 IMEI SV to net: 13 32 54 16 60 45 23 21 F6 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-36.ini Saved INI not found, loading INI list... No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Logs after writing RPL Corrupted RPL File... Scanning RPL file... NPC DATA OK... VARIANT DATA NOT FOUND... CCC DATA NOT FOUND... HWC DATA NOT FOUND... NPC APE DATA NOT FOUND... VARIANT APE DATA NOT FOUND... CCC APE DATA NOT FOUND... HWC APE DATA NOT FOUND... SIMLOCK DATA OK... SIMLOCK KEY DATA OK... SUPERDONGLE KEY DATA OK... CMLA KEY DATA NOT FOUND... WMDRM PD DATA NOT FOUND... Connecting to phone... Writing SIMLOCK DATA and SIMLOCK DATA KEY... Writing SUPER DONGLE KEY... CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 CMT Loader Ready Writing NPC DATA... Restarting phone... Done! Again logs info.after writing RPL FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 04wk47_m_v14 09-02-06 RM-36 (c) Nokia. PCI version: RFIC version: 150a160f DSP version: pb04w47v23 Retu version: 32 Tahvo version: 52 Production serial number: Product code: Module code: Basic production code: Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 355664007486883 IMEI spare to net: 3A 55 66 04 70 84 86 08 IMEI SV to net: 33 55 66 04 70 84 86 28 F6 LOCK STATUS: CONFIG KEY: FFFFFFFFFFFFFFFF PROVIDER KEY: FFFFFFFFFFFFFFFF Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 00101F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-36.ini Saved INI not found, loading INI list... No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! |
08-21-2008, 07:53 | #2 (permalink) |
Member: 164332 Status: Offline Thanks Meter: 40 | Then SX4 from.JAF BOX.los Checking for local SX card... Trying to use SX4 server... Server say: Hello! Login... Detected P-KEY: 9000A49C Server say: Login OK, you are number 2 in the queue, you must wait aprox. 5 seconds... Connecting to phone... Error receiving data from server step2... Checking for local SX card... Trying to use SX4 server... Server say: Hello! Login... Detected P-KEY: 9000A49C Server say: Login OK, you are number 1 in the queue, you must wait aprox. 0 seconds... Connecting to phone... Done! Then logs writing PM after SX4 Powering the phone... Writing PM... Field: 1, Record: 0, Len: 114 -> OK Field: 1, Record: 1, Len: 4 -> OK Field: 1, Record: 2, Len: 86 -> OK Field: 1, Record: 4, Len: 110 -> OK Field: 1, Record: 5, Len: 4 -> OK Field: 1, Record: 6, Len: 86 -> OK Field: 1, Record: 8, Len: 110 -> OK Field: 1, Record: 13, Len: 86 -> OK Field: 1, Record: 15, Len: 4 -> OK Field: 1, Record: 16, Len: 86 -> OK Field: 1, Record: 18, Len: 86 -> OK Field: 1, Record: 20, Len: 86 -> OK Field: 1, Record: 24, Len: 84 -> OK Field: 1, Record: 25, Len: 16 -> OK Field: 2, Record: 0, Len: 340 -> OK Field: 4, Record: 0, Len: 1 -> OK Field: 4, Record: 1, Len: 16 -> OK Field: 4, Record: 2, Len: 44 -> OK Field: 4, Record: 3, Len: 10 -> OK Field: 4, Record: 4, Len: 8 -> OK Field: 4, Record: 5, Len: 8 -> OK Field: 4, Record: 9, Len: 5 -> OK Field: 8, Record: 0, Len: 12 -> OK Field: 8, Record: 1, Len: 12 -> OK Field: 8, Record: 4, Len: 8 -> OK Field: 8, Record: 6, Len: 4 -> OK Field: 8, Record: 7, Len: 8 -> OK Field: 11, Record: 0, Len: 4 -> OK Field: 11, Record: 1, Len: 4 -> OK Field: 11, Record: 2, Len: 4 -> OK Field: 11, Record: 3, Len: 4 -> OK Field: 11, Record: 4, Len: 1 -> OK Field: 11, Record: 5, Len: 6 -> OK Field: 11, Record: 6, Len: 1 -> OK Field: 11, Record: 7, Len: 2 -> OK Field: 11, Record: 8, Len: 2 -> OK Field: 11, Record: 9, Len: 2 -> OK Field: 11, Record: 10, Len: 2 -> OK Field: 11, Record: 11, Len: 2 -> OK Field: 11, Record: 12, Len: 1 -> OK Field: 11, Record: 13, Len: 1 -> OK Field: 11, Record: 14, Len: 1 -> OK Field: 11, Record: 15, Len: 1 -> OK Field: 11, Record: 16, Len: 1 -> OK Field: 11, Record: 17, Len: 1 -> OK Field: 11, Record: 18, Len: 1 -> OK Field: 11, Record: 19, Len: 2 -> OK Field: 11, Record: 20, Len: 2 -> OK Field: 11, Record: 21, Len: 1 -> OK Field: 11, Record: 22, Len: 1 -> OK Field: 11, Record: 23, Len: 4 -> OK Field: 11, Record: 24, Len: 4 -> OK Field: 11, Record: 25, Len: 2 -> OK Field: 11, Record: 26, Len: 2 -> OK Field: 11, Record: 27, Len: 2 -> OK Field: 11, Record: 28, Len: 2 -> OK Field: 11, Record: 29, Len: 1 -> OK Field: 11, Record: 30, Len: 1 -> OK Field: 11, Record: 31, Len: 1 -> OK Field: 11, Record: 32, Len: 1 -> OK Field: 11, Record: 33, Len: 1 -> OK Field: 11, Record: 34, Len: 1 -> OK Field: 11, Record: 35, Len: 1 -> OK Field: 11, Record: 36, Len: 1 -> OK Field: 11, Record: 37, Len: 1 -> OK Field: 11, Record: 38, Len: 2 -> OK Field: 11, Record: 39, Len: 2 -> OK Field: 11, Record: 40, Len: 2 -> OK Field: 11, Record: 41, Len: 2 -> OK Field: 11, Record: 42, Len: 2 -> OK Field: 11, Record: 43, Len: 4 -> OK Field: 11, Record: 44, Len: 4 -> OK Field: 11, Record: 45, Len: 4 -> OK Field: 11, Record: 46, Len: 1 -> OK Field: 11, Record: 47, Len: 16 -> OK Field: 11, Record: 48, Len: 2 -> OK Field: 11, Record: 49, Len: 2 -> OK Field: 11, Record: 50, Len: 20 -> OK Field: 11, Record: 51, Len: 10 -> OK Field: 11, Record: 52, Len: 2 -> OK Field: 11, Record: 53, Len: 20 -> OK Field: 11, Record: 54, Len: 10 -> OK Field: 11, Record: 55, Len: 1 -> OK Field: 11, Record: 56, Len: 1 -> OK Field: 11, Record: 57, Len: 1 -> OK Field: 11, Record: 58, Len: 1 -> OK Field: 11, Record: 59, Len: 1 -> OK Field: 11, Record: 60, Len: 1 -> OK Field: 11, Record: 61, Len: 1 -> OK Field: 11, Record: 62, Len: 1 -> OK Field: 11, Record: 63, Len: 1 -> OK Field: 11, Record: 64, Len: 1 -> OK Field: 11, Record: 65, Len: 1 -> OK Field: 11, Record: 66, Len: 2 -> OK Field: 11, Record: 67, Len: 2 -> OK Field: 11, Record: 68, Len: 2 -> OK Field: 11, Record: 69, Len: 2 -> OK Field: 11, Record: 70, Len: 2 -> OK Field: 11, Record: 71, Len: 2 -> OK Field: 11, Record: 72, Len: 2 -> OK Field: 11, Record: 73, Len: 2 -> OK Field: 11, Record: 74, Len: 2 -> OK Field: 11, Record: 75, Len: 2 -> OK Field: 11, Record: 76, Len: 2 -> OK Field: 11, Record: 77, Len: 2 -> OK Field: 11, Record: 78, Len: 2 -> OK Field: 11, Record: 79, Len: 2 -> OK Field: 11, Record: 80, Len: 2 -> OK Field: 11, Record: 81, Len: 2 -> OK Field: 11, Record: 82, Len: 2 -> OK Field: 11, Record: 83, Len: 2 -> OK Field: 11, Record: 84, Len: 2 -> OK Field: 11, Record: 85, Len: 2 -> OK Field: 11, Record: 86, Len: 2 -> OK Field: 11, Record: 87, Len: 2 -> OK Field: 11, Record: 88, Len: 2 -> OK Field: 11, Record: 89, Len: 2 -> OK Field: 11, Record: 90, Len: 2 -> OK Field: 11, Record: 91, Len: 2 -> OK Field: 11, Record: 92, Len: 2 -> OK Field: 11, Record: 93, Len: 2 -> OK Field: 11, Record: 94, Len: 2 -> OK Field: 11, Record: 95, Len: 2 -> OK Field: 11, Record: 96, Len: 2 -> OK Field: 11, Record: 97, Len: 2 -> OK Field: 11, Record: 98, Len: 2 -> OK Field: 11, Record: 99, Len: 2 -> OK Field: 11, Record: 100, Len: 2 -> OK Field: 11, Record: 101, Len: 2 -> OK Field: 11, Record: 102, Len: 2 -> OK Field: 11, Record: 103, Len: 2 -> OK Field: 11, Record: 104, Len: 2 -> OK Field: 11, Record: 105, Len: 2 -> OK Field: 11, Record: 106, Len: 2 -> OK Field: 11, Record: 107, Len: 2 -> OK Field: 11, Record: 108, Len: 4 -> OK Field: 11, Record: 109, Len: 4 -> OK Field: 11, Record: 110, Len: 1 -> OK Field: 11, Record: 111, Len: 4 -> OK Field: 11, Record: 112, Len: 4 -> OK Field: 11, Record: 113, Len: 4 -> OK Field: 11, Record: 114, Len: 4 -> OK Field: 11, Record: 115, Len: 16 -> OK Field: 11, Record: 116, Len: 4 -> OK Field: 11, Record: 117, Len: 2 -> OK Field: 11, Record: 118, Len: 2 -> OK Field: 11, Record: 119, Len: 857 -> OK Field: 17, Record: 0, Len: 4 -> OK Field: 25, Record: 0, Len: 64 -> OK Field: 26, Record: 0, Len: 16 -> OK Field: 26, Record: 1, Len: 32 -> OK Field: 26, Record: 2, Len: 68 -> OK Field: 26, Record: 3, Len: 6 -> OK Field: 27, Record: 0, Len: 15 -> OK Field: 29, Record: 0, Len: 6 -> OK Field: 35, Record: 0, Len: 10 -> OK Field: 43, Record: 5, Len: 4 -> OK Field: 44, Record: 0, Len: 1 -> OK Field: 50, Record: 0, Len: 2 -> OK Field: 54, Record: 0, Len: 2 -> OK Field: 54, Record: 2, Len: 24 -> OK Field: 88, Record: 0, Len: 36 -> OK Field: 92, Record: 0, Len: 16 -> OK Field: 94, Record: 0, Len: 40 -> OK Field: 95, Record: 0, Len: 1 -> OK Field: 95, Record: 1, Len: 1 -> OK Field: 96, Record: 0, Len: 24 -> OK Field: 117, Record: 0, Len: 4 -> OK Field: 117, Record: 1, Len: 3 -> OK Field: 117, Record: 2, Len: 6 -> OK Field: 117, Record: 3, Len: 1 -> OK Field: 117, Record: 4, Len: 9 -> OK Field: 117, Record: 5, Len: 10 -> OK Field: 117, Record: 6, Len: 8 -> OK Field: 117, Record: 8, Len: 42 -> OK Field: 117, Record: 13, Len: 3 -> OK Field: 117, Record: 14, Len: 3 -> OK Field: 118, Record: 0, Len: 1 -> OK Field: 193, Record: 2, Len: 8 -> OK Field: 193, Record: 3, Len: 32 -> OK Field: 193, Record: 4, Len: 32 -> OK Field: 193, Record: 7, Len: 1 -> OK Field: 212, Record: 0, Len: 2 -> OK Field: 217, Record: 0, Len: 32 -> OK Field: 239, Record: 0, Len: 2 -> OK Field: 246, Record: 0, Len: 130 -> OK Field: 246, Record: 2, Len: 114 -> OK Field: 246, Record: 3, Len: 234 -> OK Field: 246, Record: 4, Len: 162 -> OK Field: 247, Record: 0, Len: 70 -> OK Field: 248, Record: 0, Len: 120 -> OK Field: 249, Record: 0, Len: 4 -> OK Field: 249, Record: 1, Len: 4 -> OK Field: 249, Record: 4, Len: 42 -> OK Field: 307, Record: 0, Len: 1 -> OK Field: 308, Record: 0, Len: 1 -> OK Field: 308, Record: 3, Len: 1 -> OK Field: 308, Record: 4, Len: 1 -> OK Field: 309, Record: 0, Len: 4 -> OK Field: 309, Record: 1, Len: 2 -> OK Field: 309, Record: 2, Len: 12 -> OK Field: 309, Record: 4, Len: 12 -> OK Field: 309, Record: 5, Len: 12 -> OK Field: 309, Record: 7, Len: 12 -> OK Field: 309, Record: 8, Len: 12 -> OK Field: 309, Record: 17, Len: 12 -> OK Done! LOGS Factory Settings .. Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 4 seconds... Done! |
08-21-2008, 07:55 | #3 (permalink) |
Member: 164332 Status: Offline Thanks Meter: 40 | Logs Unlokings....from JAF Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\355664007486883_CRT_backu p_2157198.pm Done! Backup LCK OK! Setting local mode... Reading simlock data... LOCK STATUS: CONFIG KEY: FFFFFFFFFFFFFFFF PROVIDER KEY: FFFFFFFFFFFFFFFF Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 00101F Reading imei... Reading codes data... Found codes data... Resetting phone... Waiting for phone... Reading soft info... Reading simlock data... Writing codes data... Unlock Codes: #pw+504175921618609+7# #pw+590863022549901+6# #pw+512041870428461+5# #pw+524470081452593+4# #pw+939362226181745+3# #pw+522391886059719+2# #pw+316681473320358+1# Uploading code to phone... Reseting phone... Waiting for phone... Reading soft info... Unlocking... Error unlocking... |
08-21-2008, 15:24 | #8 (permalink) |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 297936 Status: Offline Thanks Meter: 201 | In writing RPL, put the Phone in TEST MODE then try to write RPL using this version of BB5 Easy Tool: http://rapidshare.com/files/13900590..._v0.2.exe.html Hope this helps... br chronic |
The Following 2 Users Say Thank You to chronic0128 For This Useful Post: |
08-21-2008, 17:22 | #9 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: ..::Always Online::..
Member: 302397 Status: Offline Thanks Meter: 93 | Quote:
@ adonis1279......are you have any ufs-3 box ? (torando - twister - HWK) IF YES ........THEN DO THIS : 1- Connect your phone to the Tornado box ( Dont open tornado software !!) 2- open DSS software (which you used before by USB). 3- from the list select UFSx Device (c) SarasSoft. 4- PRESS CONNECT . 5- look to your phone screen (must be now in local mode ) then from the mode list ...select "TEST MODE" . 6- Wait until your phone switch to TEST MODE ....then press "WRITE RPL" ......SELECT YOUR RPL file and ...ok 7- if you got "Updating SIMLOCK DATA..fail" .....then write RPL agian & again( form 4- 10 tries) continuasly . 8- dissconnect you phone from BOX .and connect it AGAIN and see the info ......if it still configkey :FFFFFFFFFFF THEN PLZ POST here to try other way regards | |
The Following 2 Users Say Thank You to .::NaNTeC::. For This Useful Post: |
08-21-2008, 17:28 | #10 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 43
Member: 389002 Status: Offline Thanks Meter: 82 | sometimes it need to flash then write rpl.if ayaw file systemformat then write rpl...i experience in 2 units |
The Following 2 Users Say Thank You to eljhay For This Useful Post: |
08-24-2008, 04:56 | #11 (permalink) | |
Member: 164332 Status: Offline Thanks Meter: 40 | Quote:
08-24-2008, 12:16 | #13 (permalink) |
Member: 164332 Status: Offline Thanks Meter: 40 | Try writing rpl to UB box Here the logs TBB5WriteRPLThread started at: 2008/08/23 04:43:57 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Input power: 4.74V OK. Output power at Line1 3.97V is in range of: 4.00V ±10.0% APE Asic ID: 17100701 APE Asic Mode ID: 00 APE Public ID: A0E7D49FFCC03E35F035EC455B41F197060B62F7 APE Hash: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE ROM ID: AB5E4ADB27A06946 Asic ID: 000000010000022600010006000C192101002100 EM Asic ID: 00000232 EM Asic ID: 00000352 Public ID: 05E001127AD3465193A194317EFBC32489FA9AB4 Asic Mode ID: 00 Hash: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FAC901AEE CMT.NPC section parsed CMT.VARIANT section not found CMT.CCC section not found CMT.HWC section not found CMT.SIMLOCK section parsed CMT.SIMLOCK_KEY section parsed CMT.SUPERDONGLE_KEY section parsed CMT.CMLA_KEY section not found CMT.WMDRM_PD section not found APE.NPC section not found APE.VARIANT section not found APE.CCC section not found APE.HWC section not found Output power at Line1 3.97V is in range of: 4.00V ±10.0% Auto power-on mode set. Switching from Offline to Local mode... Local mode set. PRODUCTCODE set PSN set HWID set SIMLOCK section writing failed! [0x0001] SUPERDONGLE section written Power off mode set. Flashing file: BB5 [BB5 ALGORITHM] MCU File: RPL 0 kB Speed: [3000k, 3250k, 3250k, 98k] Baud. Supported Hardwares: [000C192101002100] Supported APE Hardwares: [17100701] Input power: 4.72V OK. Output power at Line1 3.95V is in range of: 4.00V ±10.0% Boot Loader: RAP3Gv2_2nd.fg 15 kB Version: 1.21.0 Supported Hardwares: [0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200] Max Flash Devices: 1 Flash ID 1: 00EC2250 - 0000 Rev: 0121 Manufacturer: Samsung MSB: 00 SectorSize: 0x020000 Signature: 00000000000000000000000000000000 Flash Loader: RAP3Gv3_algo.fg 166 kB Version: 1.31.0 Supported Hardwares: [0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002] APE Asic ID: 17100701 APE Asic Mode ID: 00 APE Public ID: A0E7D49FFCC03E35F035EC455B41F197060B62F7 APE Hash: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE ROM ID: AB5E4ADB27A06946 Asic ID: 000000010000022600010006000C192101002100 EM Asic ID: 00000232 EM Asic ID: 00000352 Public ID: 05E001127AD3465193A194317EFBC32489FA9AB4 Asic Mode ID: 00 Hash: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FAC901AEE -------------------------------------------------------------------------------- TBB5WriteRPLThread finished at: 2008/08/23 04:44:50 Terminated with error: 000100A6.000100A8.Probably wrong cable [0001107A].00011168.00011176.000115E0.00011A83 MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBQUYNAH] |
08-24-2008, 12:40 | #14 (permalink) |
Cheater -Don't Deal with him- Join Date: Mar 2005 Age: 39
Member: 132334 Status: Offline Sonork: 100.87489 Thanks Meter: 1,193 | Ok If U Don't Get Success Yet Then Read The Ask File Again & Send Me Via PM. We Give U New RPL. |
The Following User Says Thank You to NadeemShahzad For This Useful Post: |
08-24-2008, 12:47 | #15 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Atomic Mobile Solutions Age: 40
Member: 126400 Status: Offline Thanks Meter: 24 | use Uni-FBUS cable in writing your RPL. br if not it's a HW issue REWORK CMT flash chip try writing again. Last edited by gsm8g; 08-24-2008 at 12:55. |
The Following User Says Thank You to gsm8g For This Useful Post: |
VODAFONE AUSTRALIA Iphone BY IMEI Added On Gsm Father. | NadeemShahzad | Gsmfather The Wholesale Unlocking Database | 1 | 06-01-2009 19:10 |
GSM Father Team...What wrong with your BB5 Unlock Code | Mickey Mouse | Gsmfather The Wholesale Unlocking Database | 2 | 11-16-2008 08:17 |
Blackberry 8100 mep code (0) left,gsm father help me??? | adil_aimtel | Gsmfather The Wholesale Unlocking Database | 4 | 08-21-2008 14:57 |
UB logs Purchase from GSM FATHER help.. | adonis1279 | Universalbox | 1 | 07-13-2008 07:09 |
HERE IS VIDEO MANUAL FOR NEW USERS HOW TO UNLOCK BY IMEI USING GSM Father Online Term | rajan nishchal | Gsmfather The Wholesale Unlocking Database | 6 | 03-30-2008 07:13 |
