04-19-2009, 09:48 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Dipolog City
Member: 187319 Status: Offline Sonork: 100.1593798 Thanks Meter: 75 | BlackBerry 8220 successfully Unlocked Via Code ONLY (w/procedure) here's the right procedure.. How to turn Wireless Mode Off: 1. Scroll to (Turn Wireless Off.) 2. Press Select. 3. Wireless Mode will turn off. How to Unlock the device: 1. insert any sim card 2. Go to Menu 3. Go to Setting 4. Press Advance Option 5. Press Sim Card ( it shows nothing) 6. Type meppd it shows 5 Personalization: Sim -- Disable Network-- Active Network Subset -- Disable Service Provider -- Disable Corporate -- Disable 7. hold shift + alt then type mepp2 8. now it shows "Enter Network MEP Code" 9. inter your CODE. 10. BlackBerry now is Unlocked WARNING: The Wireless Mode MUST be OFF before performing the given SIM Unlock instructions in order to avoid causing the device from becoming defective. and the prof.. anyways... thanks to nonoyxp for extra help and GSMFtaher for providing the working codes.. |
The Following 6 Users Say Thank You to mitch_md3 For This Useful Post: |
Blackberry - anyway to unlock via Imei and MEP only? | Seedy | FuriousGold | 3 | 02-16-2010 11:55 |
KP107 successfully unlocked via code reading. | Haltec | VygisToolbox | 2 | 01-21-2010 15:33 |
Ku990 Viewty Successfully Unlock Via Codes | clearcom | Gsmfather The Wholesale Unlocking Database | 4 | 02-26-2008 13:10 |
