Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > Gsmfather The Wholesale Unlocking Database
Old 04-01-2008, 08:53   #1 (permalink)
Member: 704979
Thanks Meter: 14
here is how 2 enter unlock code in blackberry :)
Blackberry 8100 Code Entry Instructions
Solution
How to Enter Unlock Codes on BlackBerry 8100 Pearl:
1) Go to Options Menu => Advanced Options
2) In the SIM Card menu, hold down the shift (right of the zero, cap) press meppd
3) You'll see the unlocking level screen there you hold the ALT key (left side below @) type mepp2
*You won't see any text while you are typing either one of these.
4) Enter the unlock code.
Blackberry 8700 Code Entry Instructions
Solution
How to Enter Unlock Codes on BlackBerry 8700:
8700c Unlocking Info***** You must have a SIM card in your phone to complete these steps, I have found that this procedure works best with an AT&T or Cingular Sim card inthe phone ( Can be active or inactive ) Make sure the phone is not displaying the low battery warning! *****1. go to settings2 go to options3. go to advanced options4. go to sim card5. Type MEPD (not case sensitive) ( you will not see text appear on screenwhile typing )6. Does it say Network active? if so your phone is locked7. Hold the ALT Key while typing in MEPE ( not case sensitive ) ( you will not see text appear on screen while typing )8. It will say "Enter Network MEP Code, then you type in the 16 digit unlock code, press in the jog dial to confirm.9. Your phone is now unlocked
Blackberry 8800 Code Entry Instructions
***** You must have a SIM card in your phone to complete these steps ( Can be active or inactive ) *****
1. Go to settings menu => and then Options
3. Select Advanced options => and then Sim card
5. Type MEPD using your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD)
6. Hold the ALT Key while typing in MEPE on your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD)
8. You should be presented with a prompt "Enter Network MEP Code". Type in the 16 digit unlock code received from newmobilefreedom and press in the track wheel / jog dial to confirm
How to Enter Unlock Codes on BlackBerry 6*** 7***: ie 6230, 7100, 7290 etc..
ENTERING CODE:
Now select Options menu on BB.
Now you select SIM CARD menu.
To be able to see this you have to type this on the keypad on phone : (TEXT WILL NOT APPEAR ON THE SCREEN until you enter the unlock code)
Type 'MEPD' for all models except 7100 in which case in case use 'MEPPD'.
Usually u should see "active" NET lock. Now in order to disable this lock type 'MEP2' respectively 'MEPP2' if phone is 7100 and will appear a dialog asking for code.
NOTE: You must use the "alt" or "shift" key to enable numbers so example would be: m-e-p-"alt key"-2
Now you should see the place to enter your net unlock code.(if not, you didn't type in mep2 or mepp2 properly.)
Here you must enter the "NET Unlock Code" that the bb unlocker showed you and hit return.
Treo 680,650 600 Code Entry Instructions
Solution How to Enter Unlock Codes on Treo 600, 650 and 680 Cell Phones
1. Remove Treo battery, unplug cable
2. Insert incorrect SIM card (Any simcard that the phone does not accept)
3. Power on Treo-650, 'Sim not allowed' is displayed, click OK
4. Go to the dial pad, and use the stylus to enter MEP code . You must enter the code in the following fashion:
*#*#(MEP-CODE)# then press dial
Where (MEP-CODE) is to be replaced by the ACTUAL code supplied by the unlocking software
For example if the software supplied 12345678 as your MEP code for your phone , you must enter the code as follows:
*#*#12345678# , then press dial
Again the above numeric code is for illustration purposes, please enter the MEP code as supplied by the unlock software.
5. Phone will reset and display sim lock removed
TREO 750 UNLOCK CODE ENTRY
Insert a non native sim card (didn’t come with the phone) and when prompted for unlock code enter the code you were given.
Cingular BlackJack Code Entry
Solution How to Enter Unlock Codes on Cingular BlackJack
Insert disallowed simcard (a simcard that the phone does not usaully accept) and enter unlock codes when prompted
NOTE: If you are unable to connect to service provider or unable to make out going calls or recieve messages, this has nothing to do with your phone being locked or not, you need to force the BlackJack to change to GSM mode, this can be done as follows:
Power on your Phone
1. Enter *#1546792*#
2. Select Option 3 Network & Call Settings
3. Select option 5 Network Mode
4. Select GSM
This should resolve your problem.
HP iPaq Code Entry
Solution How to Enter Unlock Codes on HP iPaq series phones
(iPaq 6315, 6325, 6300, 6515 , etc)
1 .On the Today screen, tap Start > Settings.
2. Tap the Phone Band icon.
3. Tap the Keyboard icon to open the virtual keyboard
4. Tap Shift and then Ctl key to enable the keys.
5. Tap the blank area below the band selection box to open the unlock tool.
6. Tap Shift and then Ctl to disable the keys.
7. Enter the 8-digit unlock code and tap OK when done.
8. Wait for the device to validate the unlock code (about five
seconds). You will see one of the following screens:
-Unlock successful.
-Unlock failed due to incorrect code. The user has three attempts to
unlock. After three attempts, the device will refuse any more
unlocking attempts. Perform a soft reset to reset the counter to
perform additional unlocking attempts.
-Device is not ready for unlocking. This error message displays when
the user tries to unlock when the phone application (not the device)
is not in a steady state. It takes 30 seconds after powering on the
phone for it to reach a steady state.
Sonyericsson Code Entry
Solution How to Enter Unlock Codes on Sony-Ericsson Cell Phones
1- Switch ON your phone without Sim card
2- Press 1 time the left arrow
3- Press 2 times the button *
4- Press 1 time the left arrow
5- 'Personalize with MNC2' will appear
6- You can now enter your unlock code
If your phone has a 'JOGDIAL' (ex : SonyEricsson K700i) you must press 'Down arrow' instead of 'Left arrow' for step 2 & 3. We mean by 'Down arrow'' to direct the Jogdial down
Motorola Subsidy Code Entry
Solution How to Enter Motorola Subsidy/Unlock Codes
Switch ON your phone with a not allowed Sim card, the phone show 'Enter Special Code' or 'Enter Subsidy Code', you can now enter your unlock code.
Note: If you get the prompt "Contact Service Provider" or "Phone Blocked" , please leave your phone on at that prompt for upto 8 hours. This will reset the phone's internal timer and automatically change the prompt to "Enter Subsidy Code" , at which point you should enter the unlock codes exactly as provided.
LG Unlock Code Entry Instructions
Solution How to Enter Unlock Codes On LG Mobile Phones
Model : LG F2250
With orange sim card in the start menu tape : 2945#*3311# handset show saved then return to startup screen press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' tape your unlock code and OK.
Model : LG U8110
With not allowed sim card enter Pin code then validate tape : 277634#*#, select 'Sim Unlock' menu enter NCK code then validate, your phone is now unlocked.
Model : LG U8210
With a not allowed sim card enter Pin code then validate tape : 277634#*#, now you show test menu choose Sim test menu and tape : 2945#*#, choose Sim Unlock menu, handset show 'Enter NCK' tape code Simlock, then OK.
Model : U8150
Switch ON your phone with a not allowed Sim card, compose : 277634#*#, go to menu 'Sim Lock' and enter your unlock code.
Model : all other
Switch ON your phone with an allowed sim card and compose :
2945#*5101# - LG 510w
1945#*5101# - LG 1200 & B1200
2945#*5221# - LG 5200 & 52200
2945#*5301# - LG 5300
2945#*5401# - LG 5400
2945#*70001# - LG 7020
2945#*7101# - LG 7100
2945#*1201# - LG 1100 & 1300
2945#*70001# - LG 7250T & 1100
2945#*2201# - LG C2200
2945#*5301# - LG T5100
2945#*3311# - C3310
Go to 'Menu' and then to 'Settings', select 'Security', to finish select 'Network Provider' and select 'Desactivate' then type your unlock code.
LG CU-500 Unlock Code Entry HOW-TO
Solution How-To Enter Unlock Codes on LG CU500 mobile phones:
-Insert a non-Cingular SIM card into your LG CU 500 and power on your phone
-When you get the invalid sim-card message/prompt, enter 159753#*# on your phones keypad
-On the next screen enter the unlock code provided than press OK.
Samsung D807 Code Entry
Solution Switch on your phone with a non-accepted SIM card. The phone will ask for 'Password'.
You can now enter your unlcok code. (Even if phone doesn't ask for a password, enter the unlock code)
If 'Insert Correct SIM card' message appears: enter #0111*code#
Motorola Code Entry
IMPORTANT: You have five tries to enter this code into your phone. If you go beyond the five tries unsuccessfully your phone will not be able to be unlocked.
1. Insert the non-native(from dif provider than phone) SIM card.
2. Turn on your handset.
You will then be prompted to enter the eight digit unlock code.
Your unlock code is:
The handset is then successfully unlocked.
All other Motorola handset models use these instructions:
3. Press and hold the * key until a box appears.
4. Enter *#32#
5. Press OK
6. Enter the unlock code:
7. The handset is then successfully unlocked.
The Following 6 Users Say Thank You to mobile maker For This Useful Post:
Old 04-01-2008, 09:35   #2 (permalink)
Member: 480351
Thanks Meter: 5
please more black sir.... coz now my home is blackout...
Old 04-01-2008, 09:50   #3 (permalink)
westgold's Avatar
Member: 734668
Thanks Meter: 83
A very useful guide to all...thank for sharing
Old 04-01-2008, 16:50   #4 (permalink)
Member: 704979
Thanks Meter: 14
what happn sir du have any problem with dat
Old 04-07-2008, 22:08   #5 (permalink)
ibraheem0079's Avatar
Member: 524695
Sonork: 100.1590277
Thanks Meter: 154
great information, thanks for sharing
Old 04-12-2008, 12:10   #6 (permalink)
Member: 61959
Thanks Meter: 9
good job
thanks man for sharing
Old 05-05-2008, 08:24   #7 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Thanks Meter: 21,659
change black to white
Solution
Solution
ENTERING CODE:
Power on your Phone
4. Select GSM
HP iPaq Code Entry
-Unlock successful.
Model : LG F2250
Model : LG U8110
Model : LG U8210
Model : U8150
Model : all other
2945#*3311# - C3310
Motorola Code Entry
4. Enter *#32#
5. Press OK
The Following User Says Thank You to Ja\/\/aD For This Useful Post:
Old 05-05-2008, 09:43   #8 (permalink)
Member: 123133
Sonork: 100.999
Thanks Meter: 911
thx .::Ja\/\/aD::. for convert black to white
Old 05-05-2008, 09:47   #9 (permalink)
Member: 704979
Thanks Meter: 14
thanks bro for converted black 2 white njoyyyyyyyyyyyy
The Following User Says Thank You to mobile maker For This Useful Post:
Old 10-21-2008, 14:57   #10 (permalink)
louisgsm's Avatar
Member: 605126
Sonork: 100.1617907
Thanks Meter: 297
Thx for sharing, good job keep it up brother.
But i have blackberry 7100 when i type meppd all show but network blocked wht should i do brother.
Old 11-04-2008, 20:58   #11 (permalink)
microera's Avatar
Member: 4923
Thanks Meter: 74
Hi
I have BB 7290 and can't enter unlock code!!
I try this:
ENTERING CODE:
I can activate sim menu and I see: Network Active
but I can't enter code!?
Please for help!
p.s.
"MEP2" not working!!
Old 04-14-2009, 18:24   #12 (permalink)
Registered User
Member: 770587
Thank you for your great info....
Old 06-14-2010, 15:19   #13 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,979
great job .............................
How to enter unlock codes in samsung s3650, not accept codes when i enter,why? svchost NSPRO 22 05-07-2014 11:00
How to enter Unlock Code on BlackBerry Phones? [ONLY HERE] ::.::RAMJAN::.:: BlackBerry (RIM) 51 10-01-2012 08:52
How to Enter Unlock Code in a BlackBerry 7230 ? gsmfactory BlackBerry (RIM) 15 09-22-2012 02:18
How to Enter Unlock Codes on BlackBerry (If you get unlock code) ..::GsmEasy::.. BlackBerry (RIM) 13 11-05-2010 12:32
How to enter unlock code in blackberry 8900 Momo_Gsm BlackBerry (RIM) 4 10-23-2010 11:39
Page generated in 0.34798 seconds with 9 queries
