Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > Gsmfather The Wholesale Unlocking Database
Old 11-07-2008, 08:43   #1 (permalink)
Member: 174853
Thanks Meter: 84
HTC Simlock blocked, wait for timeout, how enter codes?
Sir i have x01HT with radio version 1.46 and it cannot enter codes, it says wait until simlock timeout (counter is blocked already)
i already downgrade and upgrade using Mr KuKu's file posted here still cant change the radio version or remove simlock blocked counter
the radio version cant be change since it is the new one
can someone advice how to remove simlock blocked counter? i want to enter codes generated by server or i must use what service to unlock at gsmfather.com?
thanks
Old 11-07-2008, 09:32   #2 (permalink)
Member: 633689
Thanks Meter: 12
if counter is blocked you should "wait about 30 minutes or more" then it should ask code, have u tried?
it has CID lock, you cant flash any other radio rom... u need CID unlock to flash rom..
if u cant unlock with code contact me i will send you CID/SIM unlock software for free
Old 11-07-2008, 12:03   #3 (permalink)
Member: 174853
Thanks Meter: 84
i already wait 48 hours hehehe no change
i already downgrade bootloader and i can flash any ROM i want but the radio just wont change...
Old 11-07-2008, 13:34   #4 (permalink)
Member: 633689
Thanks Meter: 12
have u tried this to dowgrade bootloader to 1.04 ?
Old 11-09-2008, 00:25   #5 (permalink)
Member: 174853
Thanks Meter: 84
bootloader already downgraded Sir
its the radio version that won't change, ROM version can upgrade and downgrade ...
G1 android how enter code? always ask for sign in virtue Gsmfather The Wholesale Unlocking Database 7 07-05-2009 01:36
8700c mep code block is it possible to enter code? shawgsm Gsmfather The Wholesale Unlocking Database 13 12-05-2008 07:36
[HELP] HTC reset counter, waiting for enter the code WeBoXGT UnlockBase 5 06-05-2008 17:33
How Long You waited for the MSSv4 activation code? Weasley Motorola P2k 1 04-25-2005 13:51
NEED HELP How enter code for mw 936 E? florinmar Infineon C16X M51 & ARM7 M52 BASED 3 02-10-2002 18:38
Page generated in 0.14422 seconds with 9 queries
