07-14-2009, 09:30 | #3 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2004 Location: Pakistan
Member: 51218 Status: Offline Thanks Meter: 77 | Sorry ,but your info is not correct . have a look here, http://reviews.cnet.com/smartphones/...tag=mncol;rnav WBR KHAWAR |
07-23-2009, 21:57 | #4 (permalink) | |
Banned Join Date: Mar 2005 Age: 57
Member: 123874 Status: Offline Thanks Meter: 133 | I325 Quote:
wake up stupid man.you say only stupid things.****er. if u have right u make a video to see the operation for unlok i say to all cos is better first to dannage your phone to ask informations from samsung's hacker.for example Ns Pro,Ust Pro,Spt Box,Easy Unlocker,ZT3X. etc etc They are very good to make informations for the people ...non like the other which said stupid things..... | |
06-20-2010, 15:41 | #6 (permalink) |
Junior Member Join Date: May 2010
Member: 1298867 Status: Offline Thanks Meter: 1 | If you want SPH-i325 from sprint, you can find the 16digits spc master unlock code here Samsung 16 Digit Passwords [Archive] - Mobile-Files.us Forum Follows these steps at your own risk, (it worked for me and should work for you too anyway) Then open cdma workshop, connect, and read. Open security tab, under password, select the lower option i.e the box showing FFFFFFFFFFFFFFFF, replace the FFFFFF.... with the 16digits key you got earlier, and click send, you will get a message indicating the the code was correct and yo phone is now correct. Next under MEID section, without changing the dropdown option. click on read, this will read your 6digits spc code, then type the same spc code in the box and click write, you will get a success message and your phone will also respond with a system sound, then type 000000 in the box again and click write, you will get a success message and your phone will also respond with a system sound. Your SPC code is now unlock to 000000 |
06-20-2010, 15:41 | #7 (permalink) |
Member: 1298867 Status: Offline Thanks Meter: 1 | If you want SPH-i325 from sprint, you can find the 16digits spc master unlock code here Samsung 16 Digit Passwords [Archive] - Mobile-Files.us Forum Follows these steps at your own risk, (it worked for me and should work for you too anyway) Then open cdma workshop, connect, and read. Open security tab, under password, select the lower option i.e the box showing FFFFFFFFFFFFFFFF, replace the FFFFFF.... with the 16digits key you got earlier, and click send, you will get a message indicating the the code was correct and yo phone is now correct. Next under MEID section, without changing the dropdown option. click on read, this will read your 6digits spc code, then type the same spc code in the box and click write, you will get a success message and your phone will also respond with a system sound, then type 000000 in the box again and click write, you will get a success message and your phone will also respond with a system sound. Your SPC code is now unlock to 000000. You can now use service programing in Qpst to load your new network configuration to the phone. |
The Following User Says Thank You to Ogbenieko For This Useful Post: |
07-03-2012, 12:27 | #8 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Monrovia
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | Quote:
The Following User Says Thank You to amanvir For This Useful Post: |
unlock samsung i325 | celutop82 | UST Pro II | 2 | 09-09-2011 10:06 |
samsung i325 spc | chaparro | Various CDMA/TDMA Cell Phones | 2 | 06-20-2010 18:46 |
ATENTION samsung i325 | kenawih | Easy-Unlocker | 16 | 12-31-2009 14:19 |
Keypad for Samsung I325 Phone (Black) - Original (new) | IPMART | ipmart WebShop | 0 | 08-03-2009 15:20 |
Help unlocking Samsung sph-i325 | justwoman | VLSI, Conexant, Skyworks and Old Models | 0 | 06-03-2009 22:15 |
