Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > Gsmfather The Wholesale Unlocking Database
Old 01-02-2009, 06:44   #1 (permalink)
ryumahon's Avatar
Member: 4021
Thanks Meter: 781
palm centro unlocking problem... kindly check
i have here one palm centro... at first it wont accept the code with or without UN-ACCEPTED SIM.... so i decided to put an AT&T card to it and put the codes in... luckily the codes of the phone was disabled...
now here is the problem... each time i turn off the phone and enter a NEW SIM.. still it displays sim is unaccepted...
even for how many times i try and try still the same results!! can you please guide me what to do??
thanks and best regards!!
br
Old 01-06-2009, 01:06   #2 (permalink)
ryumahon's Avatar
Member: 4021
Thanks Meter: 781
still no reply from support team??? its been 4 days already..... can you please refund my credit instead so that ill return the unit to my customer if there is no solution..
thanks!
Old 01-07-2009, 03:34   #3 (permalink)
ryumahon's Avatar
Member: 4021
Thanks Meter: 781
still no reply... all other threads were replied but mine just left unanswered! is there any way or not?
Old 09-05-2009, 00:29   #4 (permalink)
Member: 312383
Thanks Meter: 6
treo centro unlock problem
I have the same problem, treo centro from att, if i put in att sim and input unlock code, it will say sim lock has been remove ..... after that i pull out battery and put in tmobile sim, it say sim not allow ???any ideal??
Old 10-04-2009, 00:27   #5 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 769
same here, maybe hard reset will fix it?
Old 10-04-2009, 00:59   #6 (permalink)
nelsky's Avatar
Member: 583353
Thanks Meter: 257
same problem here...
any solution from solution..
br,
Old 10-04-2009, 04:28   #7 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 769
solution is jic online code reader, because most centro codes from code providers are wrong (search their forums with many complains about wrong centro code), and with original sim in centro any code will say "sim lock has been removed" the key is to enter the received code with wrong sim in centro and only if it says "...removed" then code is the correct one, which happens sometime (receiving the correct code). so buy a log from jic and use the code reader via palm sync and it will 100% work.
Old 10-06-2009, 12:01   #8 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,686
yes youre correct, most palm centro is refurbished thats why many are wrong code
br
Please Help With Palm Centro Unlock 232323 Phone Unlocking Codes & Maps 2 12-23-2009 06:50
Palm centro unlocking problem shiehd PalmOS /HP and others 7 12-26-2008 08:44
palm centro unlock how ? PATELKETAN Easy-Unlocker 2 07-26-2008 13:28
palm centro unlock how ? PATELKETAN PalmOS /HP and others 1 07-15-2008 23:33
Page generated in 0.32917 seconds with 8 queries
