Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > Gsmfather The Wholesale Unlocking Database
Old 03-18-2008, 22:45   #1 (permalink)
msa
Member: 17424
Thanks Meter: 13
Problem running software
Hi
I am having problems running the software both on Xp and Vista. Any ideas what I need to do?. I have Installed .net
please have look at attached pictures for errors.
br
msa
Old 03-19-2008, 07:39   #2 (permalink)
sunnyc's Avatar
Member: 49495
Sonork: 100.9 & 100.12345
Thanks Meter: 1,009
It seems that you are running the exe on the local network (LAN). If so please copy it to your location machine, then you will not get this error. If you still what to run the exe on the LAN then you may need to configure your .NET framework security settings
Please try to avoid the following settings:
You can do the following (but plz make sure you are doing to same as bellow):
OPEN COMMAND PROMPT
GOTO THE FOLLOWING PATH
%windir%\Microsoft.NET\Framework\v2.0.50727
ENTER THE FOLLOWING COMMAND
caspol.exe -m -ag LocalIntranet_Zone -url \\<network host>\<share name>\ FullTrust -n FullTrustShare
Sunnyc
Old 03-19-2008, 17:35   #3 (permalink)
msa
Member: 17424
Thanks Meter: 13
Thanks for your help. Yes I was trying to run the programe over netqwork drive. Copied to Pc and all works fine.
br
msa
Old 03-20-2008, 02:27   #4 (permalink)
UHK
Member: 13737
Sonork: 100.100725
Thanks Meter: 193
br
msa
how are you Mr Server I hope you are ok
1 of my special customer
Problem Running USF-3 Software Jasont81 Twisterflasher 4 01-15-2007 18:49
can't run software gorgans ThunderStorm Box 2 11-19-2005 03:12
Page generated in 0.37081 seconds with 9 queries
