Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > Gsmfather The Wholesale Unlocking Database
Old 03-29-2009, 03:17   #1 (permalink)
Member: 31942
Thanks Meter: 42
treo 650 unlock code problem
can you check whats the problem with my treo650 cause i ordered codes from gsmfather. treo 650 cingular locked with imei: 354427005845547 and i recieved code: 70189129. but when i enter the code it tells me locked, the sim lock has not been removed from this phone. can you please check my unlock code. thanks
Old 03-29-2009, 03:28   #2 (permalink)
Member: 51453
Thanks Meter: 729
check your imie if you have send correct imei.if it is correct then contact gsmfather they can help you with your unlocking code
br
Old 03-29-2009, 03:35   #3 (permalink)
Member: 31942
Thanks Meter: 42
yap double checked imei its correct and tried hardreset the unit also but to no avail. already contacted gsmfather. waiting for their reply.
Old 03-30-2009, 12:51   #4 (permalink)
Member: 31942
Thanks Meter: 42
any help here from gsmfather support.
Old 03-30-2009, 13:31   #5 (permalink)
:::GsmFather:::'s Avatar
Member: 24066
Sonork: 100.9
Thanks Meter: 574
Hard reset the phone once. and put non accepted sim card and enter code again. it should work
Old 03-30-2009, 14:04   #6 (permalink)
Member: 31942
Thanks Meter: 42
hardreset it many times. installed other non acepted simcard still same problem. it can only accept original cingular sim.
Old 03-30-2009, 14:06   #7 (permalink)
Member: 31942
Thanks Meter: 42
hardreset it many times. installed other non acepted simcard still same problem. "the sim lock has not been removed from this phone" . it can only accept original cingular sim.
Old 03-30-2009, 15:13   #8 (permalink)
Member: 24066
Sonork: 100.9
Thanks Meter: 574
ok give me imei so i can refund you. buy "jic technology" log from client software it cost 13 credits, you can unlock 2 phones in that. you will get user name password. download software and manual from below link and unlock your treo 650.
http://www.cheapunlock.com/jic.zip
Old 03-31-2009, 02:43   #9 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
dear gsmfather team dennis used my acct for this unlocking process.image included for the imei of the treo650 unit....pls advice us what to do next?thanks
Old 03-31-2009, 14:47   #10 (permalink)
Member: 31942
Thanks Meter: 42
what is the update for this? refund credit?
Old 03-31-2009, 15:02   #11 (permalink)
Member: 124069
Thanks Meter: 59
refunded. you can unlock it using info from post #8 above.
Old 03-31-2009, 16:00   #12 (permalink)
Member: 767451
Thanks Meter: 178
and me ihave treo650 restart show only paim one then restert pls help what can i do? thanks
Old 05-20-2013, 18:47   #13 (permalink)
Member: 1937484
gsmfather
i need your help with all due respect to unlock my treo 650 phone.
imei = 354427003752315
unlock data = 7QHGN-GAOUZ-UARUO-ZGHV3-K56YB-57EQE-J3GKI-A2O3Y
kindly let me hear from you.
thank you in advance...
Old 05-20-2013, 19:13   #14 (permalink)
Member: 1937484
Urgent treo 650 unlock code
gsmfather
treo 650 unlock code Pratik1204 Phone Unlocking Codes & Maps 3 10-30-2008 06:37
treo 650 unlock code unlock expert tech FuriousGold 0 02-27-2008 17:22
WRONG CODE in TREO 650 UNLOCK TXT to CODE !!! humbedj FuriousGold 4 06-08-2007 19:39
Cingular Treo 650 Unlock Code ekokobe Phone Unlocking Codes & Maps 1 12-24-2006 22:52
Treo 650 unlocking with IMEI and Code ? voicestream PalmOS /HP and others 2 09-21-2005 18:53
Page generated in 0.40085 seconds with 8 queries
