01-13-2010, 06:03 | #1 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 337450 Status: Offline Thanks Meter: 718 | 16gb 3GS iphone shorted. I never seen a successful repair for this kind of problem, shorted board, Pmic (for 3gs) gets hot, even removing the 3 power amplifiers don't work, still board shorted. The glue use on i-phone's board is a kind not ordinary unlike on nokia's. Removing glue parts will damage the parts as i tried, but pins on board is intact. Some possible reasons why those iphone get shorted and died permanently are: 1. user's use a third party charging device. 2. Factory defects, modified by suppliers but no reasons why they did it. 3. Over charged? electric current problem? 4. Water damaged! Solutions are not applicable I think, i-phone is made not repairable by hardware? no diagram avalable, no schematic... if you got solutions pls post it here, thanks. |
01-13-2010, 06:16 | #2 (permalink) |
Freak Poster Join Date: Jun 2007 Location: India
Member: 529040 Status: Offline Thanks Meter: 13 | Quote: Remove power amp and it will solve ur prob |
01-13-2010, 06:31 | #3 (permalink) | ||
Member: 337450 Status: Offline Thanks Meter: 718 | @mukesh_b Quote:
The Following User Says Thank You to yobb For This Useful Post: |
01-13-2010, 06:33 | #4 (permalink) | ||
01-13-2010, 09:58 | #6 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Greenhills,Ph
Member: 99827 Status: Offline Thanks Meter: 56 | Replacing Power Management IC would help you. Shorted iPhone,usually arise from, using sub-standard cables and power adapters. Some experiences arise also, when iPhone docks at dock speakers. |
04-09-2010, 21:47 | #8 (permalink) |
No Life Poster Join Date: Apr 2006 Location: eproom memory Age: 41
Member: 264366 Status: Offline Thanks Meter: 29 | Hey guys is there any solution out for this problem ... I have a 3gs 16gb and the PMIC got very very hot when put battery , and there is short circuit on batery conector of motherboard . Please post solution if anybody fixed it . Thanks |
04-11-2010, 09:24 | #10 (permalink) |
Freak Poster Join Date: Jul 2000 Location: GabiRo
Member: 1675 Status: Offline Thanks Meter: 44 | general solution Hi i try to help u and all with ageneral solution for all short circuited pcb's. take an external power supply with 2-3 A power and without protection for short circuit and connect the 3.8-4.00 v at the pcb's battery contact(becarefull for polarity coz its difficult to found from pcb,check at battery) and try to found witch part are going hot. If its from some chip(s) fault and not psysical short circuit from pcb lines or from any capacitor u will have many chances to find the defective part. Best Regards GabiRo |
The Following User Says Thank You to GSMan For This Useful Post: |
04-11-2010, 12:57 | #11 (permalink) |
Member: 264366 Status: Offline Thanks Meter: 29 | i dont know if it is the PMIC defectiv or not , but it get very very hot after 5 sec when put battery on contact with pcb ; may be du to another defectiv parts pmic get very hot ? And pmic not available in my country also . Is the 3g and 3gs PMIC are same ? ? ? |
08-04-2010, 09:32 | #15 (permalink) |
Junior Member Join Date: May 2010 Location: On earth, for sure :D Age: 40
Member: 1296187 Status: Offline Sonork: zaq Thanks Meter: 2 | hi bro i have a problem whith iphone 3gs , not seen anything on the LCD , i have replace lcd but nothing :S:S:S:S:S pleas help me bro ! |
Iphone 16gb 3gs | aj4u | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 01-08-2010 09:04 |
