Old 01-13-2010, 05:03   #1 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 718
16gb 3GS iphone shorted.
who has successfully repaired a shorted iphone? any generation?
I never seen a successful repair for this kind of problem, shorted board, Pmic (for 3gs) gets hot,
even removing the 3 power amplifiers don't work, still board shorted. The glue use on i-phone's board is a kind not ordinary unlike on nokia's. Removing glue parts will damage the parts as i tried, but pins on board is intact.
Some possible reasons why those iphone get shorted and died permanently are:
1. user's use a third party charging device.
2. Factory defects, modified by suppliers but no reasons why they did it.
3. Over charged? electric current problem?
4. Water damaged!
Solutions are not applicable I think, i-phone is made not repairable by hardware? no diagram avalable, no schematic...
if you got solutions pls post it here, thanks.
Old 01-13-2010, 05:16   #2 (permalink)
Member: 529040
Thanks Meter: 13
4. Water damaged!
Remove power amp and it will solve ur prob
Old 01-13-2010, 05:31   #3 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 718
@mukesh_b
maybe u miss to read... thanks anyway.
The Following User Says Thank You to yobb For This Useful Post:
Old 01-13-2010, 05:33   #4 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 718
@mukesh_b
Old 01-13-2010, 08:07   #5 (permalink)
Registered User
Member: 321917
Thanks Meter: 19
try change gps and pmic.... solve problem tested 100%
The Following 2 Users Say Thank You to adjibt For This Useful Post:
Old 01-13-2010, 08:58   #6 (permalink)
Mad Scientist's Avatar
Member: 99827
Thanks Meter: 56
Replacing Power Management IC would help you.
Shorted iPhone,usually arise from, using sub-standard cables and power adapters.
Some experiences arise also, when iPhone docks at dock speakers.
The Following 2 Users Say Thank You to Mad Scientist For This Useful Post:
Old 01-14-2010, 14:08   #7 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 718
@Mad Scientist
not work, still board is short...
Old 04-09-2010, 21:47   #8 (permalink)
johnreza's Avatar
Member: 264366
Thanks Meter: 29
Hey guys is there any solution out for this problem ... I have a 3gs 16gb and the PMIC got very very hot when put battery , and there is short circuit on batery conector of motherboard .
Please post solution if anybody fixed it .
Thanks
Old 04-10-2010, 15:06   #9 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 718
@johnreza
Replace it if u had parts available..
Old 04-11-2010, 09:24   #10 (permalink)
GSMan's Avatar
Member: 1675
Thanks Meter: 44
general solution
Hi
i try to help u and all with ageneral solution for all short circuited pcb's.
take an external power supply with 2-3 A power and without protection for short circuit and connect the 3.8-4.00 v at the pcb's battery contact(becarefull for polarity coz its difficult to found from pcb,check at battery) and try to found witch part are going hot.
If its from some chip(s) fault and not psysical short circuit from pcb lines or from any capacitor u will have many chances to find the defective part.
Best Regards
GabiRo
The Following User Says Thank You to GSMan For This Useful Post:
Old 04-11-2010, 12:57   #11 (permalink)
johnreza's Avatar
Member: 264366
Thanks Meter: 29
i dont know if it is the PMIC defectiv or not , but it get very very hot after 5 sec when put battery on contact with pcb ; may be du to another defectiv parts pmic get very hot ?
And pmic not available in my country also .
Is the 3g and 3gs PMIC are same ? ? ?
Old 04-11-2010, 13:45   #12 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 193
There is 4 power amps, one for gsm/3g and 3 for wcdma .
Remove all power amplifiers .
Old 04-14-2010, 14:27   #13 (permalink)
Member: 221978
Thanks Meter: 11
I have an iPhone 3G which gets hot on the CPU. What to do in this case?
Regards
Old 07-06-2010, 14:08   #14 (permalink)
Member: 496786
Thanks Meter: 72
i have same problem i remooved power amb still same problem
Old 08-04-2010, 09:32   #15 (permalink)
Member: 1296187
Sonork: zaq
Thanks Meter: 2
hi bro i have a problem whith iphone 3gs , not seen anything on the LCD , i have replace lcd but nothing :S:S:S:S:S pleas help me bro !
Iphone 16gb 3gs aj4u iPhone 2 / iPhone 3G / iPhone 3GS 1 01-08-2010 08:04
Page generated in 0.38439 seconds with 8 queries
