02-09-2008, 15:42 | #1 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | 2G iPhone F.A.Q. 1 How To Check Version? A. Type This Code "*3001#12345#*" And Press Call Button.Then Go To About And Check Modem Version Its Should Be Like This 3.14.08_g Modem Version = 1.0.2 Firmware Version 4.01.13_g Modem Version = 1.1.1 Firmware Version 4.02.13_g Modem Version = 1.1.2 Firmware Version 4.03.13_g Modem Version = 1.1.3 Firmware Version 4.04.05_g Modem Version = 1.1.4 Firmware Version 4.05.01_g Modem Version = 2.0.0 Firmware Version B. If You Have Jail Breaked Means You Have You Are Able To Use Your Spring Board(Deskboard) You Can Go To General-->Setting--> About And See Modem Version As I Writed Above. 2 DO I NEED TO DOWNGRADE TO UNLOCK ALL IPHONE FIRMWARE? A. Check Modem Version Before Doing Anything At Phone. If You Have Old Version Of Modem You Don't Need To Do Any Downgrade. B. If You Have Modem 4.02.08g Or New You Need To Downgrade Your Modem Version To Unlock Phone. C. New Update "gunlock" Able To Patch Both New Modem Version So NO NEED TO DOWNGRADE NEW MODEM VERSION.LINK FOR STEP BY STEP UNLOCK.. HERE 3 Why Should I Downgrade Modem Version And Firmware Version? A. Modem Version Need To Downgrade To Unlock.4.01.08g Is Last Version Which Is Able To Patch With Anysim. B. Phone Firmware Need To Downgrade To Jailbreak It. 4 How Can I Update And Downgrade My Iphone? A. Only ITUNES Is Able To Downgrade And Update Your Iphone. There Is No 3rd Party Flasher For This Phone Yet. B. Press Shift And Press Restore To Select Your Firmware And ITunes Will Write To Phone. C. Press Shift And Press Update To Select Your Firmware And ITunes Will Write To Phone. D. Without Pressing Shift If You Press Update Or Restore Its Download Latest Version From Internet And Write To Phone. 5 What If I Remove Iphone At Case Of ITunes Is Restoring Or Updating. A. There Is Recovery Mode By Pressing HOME AND POWER ON Button. B. Some Case Recovery Mode Not Stable So You Should Go To Recovery Mode Then Use Ibrickr To Put Phone DFU Mode. Wight Lcd Mode You Get. Now You Can Do Restore Or Update With Selected Files Only. 6 How To Do Jailbreak Of Iphone? And What Its Use For? A. Jailbreak = Activation Bypass Via Hacking Method. Non Official Method. Its Let You To Open Spring Board (Deskboard)Without Paying To At&T. B. Its Done Via 2 Way. (1)Via Wifi And 1.1.1 Firmware In Iphone You Must Have (2) Via Pc And Ibrickr Software You Must Have 1.0.2 Firmware In Phone. C. Ibrickr Is Standalone. D. Wifi Base 1.1.1 Jail Break Need Shared Internet Connected Over Wifi Modem Or Pc Hub. 7 I Have New Modem Version Iphone What I Do? A. Please Read First Post If You Have 1.0.2 Do Jailbreak And Unlock Via Anysim. B. If You Have 1.1.1 Still Possible To Use Anysim And Jail Break Via Wifi Method Link Come Soon <<HERE>>. C. If You Have 1.1.2 From Factory Then Read (1).If You Have 1.1.2 Updated Mystically Then Read (2) (1) Factory Base 1.1.2 Have New Bootloader 4.6 So You Can't Use Existing "Ieraser" To Erase Baseband And "bbupdator For Wring Modem Flash And Eeprom". (2) Mystically Updated 1.1.2 Still Have Old Bootloader 3.9 So There Is Many Trick To Downgrade Iphone Modem Version To Old Version. Link Will Come Soon <<Here>>. D. If You Have Factory 1.1.3 Its Have New Very Well Protected Baseband And New Bootloader4.6.. So First You Have To Do Downgrade Bootloader Then Firmware Then Modem Then Unlock Possible. So Right Now Only Tp Method Is Able To Downgrade This Phone Bootloader. Which Is Too Risky But Working. Link Will Come Soon <<Here>>. E. New Update "Gunlock" Able To Patch Both New Modem Version So NO NEED TO DOWNGRADE NEW MODEM VERSION. LINK FOR STEP BY STEP UNLOCK.. HERE 8 I Got Iphone Connected To Pc Its Only Detect In Recovery Mode What I Do?? A. Simple And Easy Method Is Use Ibrickr Its Show You 2 Option Reboot In Normal Mode. Click On It.. If You See Green Read Next Point. If You See Red Means Ok Wait For Few Minutes. You Are Back To Activation Screen Or Main Deskboard. B. If Green Screen Means Firmware Is Damaged. Need To Restore With ITunes. Do It. 9 I Got Iphone Its Show Iphone Need Repair What I Do? A. If You Have Old Bootloader Then You Should Use "virginise.sh" Method To Repair. Its Fast And Easy Method. Link For Step Will Come Soon <<<Here>>> B. If You Have New Bootloader Or Old And Want To Do Hard Way Then Use 1.1.3 Firmware Link At Down. Use ITunes Press Shift Update And Let Him Updated. Now You Get Imei Repaired. Now Restore 1.1.1 Firmware. Now Do Jail Break As Showed In Part 1. Link Is Here Now Do Unlock As Part 2 Show. Link Is Here Now Restart Phone And Check I Am Sure You Have Working Phone With WiFi .. Now Pre Update To Any Version As You Want. 10 How Do I Repair Crash And Not Dial Number On Firmware 1.1.2If My Country Is Not Listed In Iworld?? TAKE ONLY 1HRS TO LEARN AND FIND SOLUTION..THANK TO USER WHO FORCED ME TO FIND AND DO ANYTHING FOR SOLUTION. A. You Have To Update Your Country Code And Name In country.plist at /application/Iworld/ For Example I Have "India" Country Code "91" And Tag "in” So I Put This Line In country.plist <key>91</key> <string>in</string> And Save And Re upload File To Phone..Off It And On It Again Bingooo You Get Your Country Now In Iworld......Select It And Fix Your Iphone Boys.. 11 What I Do If My Iphone Show No Network Its Only Show No Service With All Sims? A. Very Basic Reason Is Phone Network Setting. Go To Setting ---> General ---> Reset ---> Select Reset All Setting.. Now You Phone Will Restart And You Get Network If Not Use B B. Main Reason To Not Net Network Is Jail Break Or Bad Imei So First Check Imei With *#06# If Ok Do Restore Any Firmware And Back To Activation Screen. Now Insert Any SIM If You See Its Show Insert Correct SIM Or Wrong SIM Or Anything Which Showed In Locked Condition Dial Emergency Number If Its Call Means Ok Phone Hardware Is Working Perfect. Now Do Unlock Jail Break And Activation. If You Still Not Getting Network Do Point A C. Last But Not Least If You Are Not Able To Dial Emergency Number There Is 80% Chance Phone Have Hardware Problem. To Be Confirm You Have To Go To Setting ---> General ---> Reset ---> Reset All Setting This Will Clear Everything In Phone Including Some Data And Network Setting. If You Get Network Then Good. But If You Not Then Very Strong Reason To Check Phone At Hardware. ONE MORE SOLUTION FOUND SO ITS HERE. D. I Have Done Some Extra Hard Test On No Service No Network And Found If You Are Able To Make Emergency Call Then 100% Software Problem What I Have Done Is Tried All Firmware With RESTORE . V1.1.1, V1.1.2, V1.1.3, V.1.1.4 But Phone Was Always No Service. Simple I Just Restore Again One Firmware And Back To Activation Screen And Done UNLOCK JAIL BREAK AND ACTIVATION Now At No Service No Network Skip This Part If You Already Have It. Open Ziphone Go To Advance Option Tick On Downgrade Bootloader And Click On Perform Actions.. Now You Must Get Networkkkkkkkkkk 12 what i do if my phone show this error when i start it? Quote:
13. what to do for i have Iphone with firmware 2.0 only show recovery mode OR i want to downgrade and unlock activation and jailbreak? a. there is 2 way to do this. [1] make custome firmware and restore it to phone at DFU mode.. you have to use hardware dfu mode because 2.0 firmware don't have any software dfu mode. [2] you can restore 1.1.4 firmware but phone should be in DFU mode.. you have to use hardware dfu at end you get error but its ok. now open kiphone (modified ziphone version)to erase your 2.0 baseband (modem firmware) tick on downgrade baseband and debug mode press start yes your phone is in recovery mode i know still saying you to do that so do it. ok at end you will land at recovery mode or normal mode. if your phone is in normal mode reboot it to recovery mode and select 1.1.4 firmware again yes once again. if your phone is in recovery mode already just select 1.1.4 firmware and restore again yes once again. now your phone restore will take much then normal but now you DON'T GET ERROR AT END OF RESTORE. now phone is ready at activation screen and 1.1.4 now ready to use with ziphone and DO IT ALL. 14. How To Differentiate Between Iphone 2G And Iphone 3G Physically? A. Iphone 2G = Steel Backcover And An In Case Headphone Jack B. Iphone 3G = Black Or White Plastic Backcover, And Standard Headphone Jack And 2 Screws At The Dock Connector Regards To Willmaster For Information. I Will Update This FAQ With Working Unlock Method. Any One Want To Write Working And Tested Tutorial With Image Of Iphone Unlock Or Perfect Method Pm Me I Check It And If All Ok Then Add Your Thread Link To This One So Every One Get Help.. Link For Firmware If Any One Need. 1.0.0: iPhone1,1_1.0_1A543a_Restore.ipsw 1.0.1: iPhone1,1_1.0.1_1C25_Restore.ipsw 1.0.2: iPhone1,1_1.0.2_1C28_Restore.ipsw 1.1.1: iPhone1,1_1.1.1_3A109a_Restore.ipsw 1.1.2: iPhone1,1_1.1.2_3B48b_Restore.ipsw 1.1.3: iPhone1,1_1.1.3_4A93_Restore.ipsw 1.1.4: iPhone1,1_1.1.4_4A102_Restore.ipsw Best Regards Gopal Chevli Last edited by stanner_austin; 08-24-2008 at 10:10. Reason: added point 14 | |
The Following 198 Users Say Thank You to stanner_austin For This Useful Post: |
02-12-2008, 22:09 | #3 (permalink) |
No Life Poster Join Date: Mar 2003 Location: USA N China
Member: 24066 Status: Offline Sonork: 100.9 Thanks Meter: 574 | Also put 1.1.2 and 1.1.3 unlock in sticky for the members who dont know yet to unlock 1.1.2 and 1.1.3 some still using Turbo,xsim,3gpp etc etc sims for unlocking. |
The Following 2 Users Say Thank You to :::GsmFather::: For This Useful Post: |
02-13-2008, 08:31 | #4 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Seraat-e-Mustaqeem Age: 38
Member: 228476 Status: Offline Sonork: 100.1575078 Thanks Meter: 114 | Realy Gud job Dear u've done realy Good Work. Keep it up n keep in touch. |
The Following User Says Thank You to Adil Mobiles For This Useful Post: |
02-15-2008, 13:19 | #5 (permalink) |
No Life Poster Join Date: May 2005
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks Meter: 341 | exilent thread. many thanks to stanner_austin. but the problem is i didnt find any update button on i tunes. little bit more help need here. thanks again |
The Following User Says Thank You to Softway For This Useful Post: |
03-02-2008, 22:13 | #8 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::Always Online::..
Member: 302397 Status: Offline Thanks Meter: 93 | THANKS FOR THE GREAT POST NOW I READ ALL THIS EXIPLATION AND MY IPONE IS: 3.14.08.g Modem Version = 1.0.2 Firmware Version AS I UNDERSTAND FROM YOUR POST DONT NEED TO DOWNGRADE .......... AND MY IPHONE IS FREE (I CAN OEN ANYTHING AND NOT JAIL) WHAT THE CLEAR AND EASY STEPS TO UNLOCK MY IPHONE?????? |
The Following 2 Users Say Thank You to .::NaNTeC::. For This Useful Post: |
03-03-2008, 08:16 | #9 (permalink) | |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Quote:
unlock with any sim | |
The Following 3 Users Say Thank You to stanner_austin For This Useful Post: |
03-06-2008, 20:18 | #10 (permalink) |
Freak Poster Join Date: May 2005 Age: 58
Member: 148096 Status: Offline Thanks Meter: 7 | help needed when i run ziphone 2.4 installation exe,i get cant install zphon~1.exe error,then when I try to run this application it always said this THIS APPLICATION FAILED TO START BECAUSE THE APPLICATION CONFIGURATION IN INCORRECT . REINSTALLING APPLICATION MAY FIX THIS PROBLEM how to solved this ?ive tried all versions and still get the same errors,im running win xp and ive installed net framework v2 thanks in advance wolfe |
The Following 2 Users Say Thank You to wolfecom For This Useful Post: |
03-06-2008, 20:27 | #11 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | If you get error "The application failed to initialize properly (0xc0000135)" you need to install .NET Framework 2.0. you have this at your pc?? |
The Following 5 Users Say Thank You to stanner_austin For This Useful Post: |
03-06-2008, 20:35 | #12 (permalink) |
Member: 148096 Status: Offline Thanks Meter: 7 | thanks for reply stanner austin error i get is cant install zphon~1.exe error,when i try to install ziphone i have already downloaded and installed dot net framework 2 but i still get the same error and wjhen i go to prog files and run ziphone the error i then get when i try to open prog is THIS APPLICATION FAILED TO START BECAUSE THE APPLICATION CONFIGURATION IN INCORRECT . REINSTALLING APPLICATION MAY FIX THIS PROBLEM thanks again inadvance wolfe |
03-06-2008, 20:39 | #13 (permalink) | |
http://www.downloadziphone.org/ download win ziphone. and extract to folder. now see.and make image what type of error u get so i can understand more better. | |
The Following User Says Thank You to stanner_austin For This Useful Post: |
03-06-2008, 21:17 | #14 (permalink) |
Member: 148096 Status: Offline Thanks Meter: 7 | ok ive downloaded ziphone win-2.5c and installed it but when it finished installing i get an error box that says "cant install zphon~1.exe" im running a dual boot system so it is unzipped into folder on d:/ prog files and if i try to run the exe from the folder i then get an error box saying "THIS APPLICATION FAILED TO START BECAUSE THE APPLICATION CONFIGURATION IN INCORRECT . REINSTALLING APPLICATION MAY FIX THIS PROBLEM" ive made screen shots of errors but there is an error on this page and it will not let me attach jpg screen shot images |
myX-2G strange problem | dandoc2 | ARM9 BASED M62 / M62+ | 5 | 04-22-2004 16:05 |
3G Phone - 2G Sim | Mildred_iii | Motorola P2k | 1 | 04-15-2004 01:13 |
how to switch 7600 from 3g to 2g | ali-g-string | Nokia Digital Core Technology 4 ( DCT-4 ) | 22 | 04-07-2004 16:01 |
MYX-2G problems reading field 5709 | javilinjavilon | ARM9 BASED M62 / M62+ | 7 | 03-31-2004 19:23 |
