Old 12-07-2010, 00:53   #1 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
3gs update without baseband -> easyest way ever!
after many different trys with tinnyumbrella and deleting the bootloader from the ipsw files, i found my own way...
when you load your restore file into itunes, itunes connect to
sourik server (if you set hosts file) or to apple server.
if blobs are saved or apple is signing your fw you whant to write to phone, then it starts flashing...
now you see on your iphone the progressbar.
now just disconnect your internet connection
because itunes whant to get baseband signature from apple server, it trys to connect to the apple certifacte server, but since you disabled the internet access, itunes whont get the certificate and therefore it cant update your baseband and will quit with error code... THATS GOOD!
now kick your iphone out from recovery mode with tinny umbrella or iRep or whantever else you prefer to use...
your iphone is now starting with new fimrware and old baseband!
ATTENTION: i have tested it with 3G and 3GS
3G is NOT WORKING, it will update the baseband!
3GS is 100% working with my methode!
4G i dont know... dont have tested it.
so for 3GS this is the saves prozess to make update without updating your baseband....
DONT USE THIS METHODE WITH NORMAL iPHONE 3G!
i think with iphone 4 it should work too..
wbr.
hari
The Following 18 Users Say Thank You to oOXTCOo For This Useful Post:
Old 12-07-2010, 01:16   #2 (permalink)
misiu22's Avatar
Member: 661523
Thanks Meter: 205
wbr.
hari
Does this work for firmware 4.2.1?
Will you be able to kick out from recovery mode after that you have flashed 4.2.1?
Thanx for great info!
br misiu22
Old 12-07-2010, 02:10   #3 (permalink)
Member: 565487
Sonork: 100.1590618
Thanks Meter: 35
wbr.
hari
please step by step with photo...
thanks great info...
Old 12-07-2010, 03:30   #4 (permalink)
Member: 1296356
Sonork: n/a
Thanks Meter: 40
Help me brother step by step with picture
Thanks..
Old 12-07-2010, 03:47   #5 (permalink)
dArk_shAdE's Avatar
Member: 943187
Thanks Meter: 584
need more details...need pictures or procedure......
The Following User Says Thank You to dArk_shAdE For This Useful Post:
Old 12-07-2010, 05:54   #6 (permalink)
gwaai's Avatar
Member: 49581
Thanks Meter: 73
pictures and steps?
yo, he has wrote it very clearly ...
DISCONNECT INTERNET after your itune start updating your phone ...
that is all
The Following User Says Thank You to gwaai For This Useful Post:
Old 12-07-2010, 06:12   #7 (permalink)
Member: 60474
Thanks Meter: 658
wbr.
hari
guys just follow this guide. working perfectly...
http://forum.gsmhosting.com/vbb/f456...guide-1154534/
Old 12-07-2010, 07:38   #8 (permalink)
jap_line's Avatar
Member: 758106
Sonork: jap_line
Thanks Meter: 412
very nice trick!
my only question is, this is for 4.2.1 right?
the problem on 3gs (NB) 4.2.1 now is "thetered" when you jailbreak even you have lower baseband, so it still a problem
it's still better to stay away from 4.2.1 (for unlockers) so you can avoid thetered jailbreak problem and stay 4.1 and lower am i right?
btw,
again very nice trick sir.oxcto i know this can be useful in some way
Br.
The Following User Says Thank You to jap_line For This Useful Post:
Old 12-07-2010, 08:05   #9 (permalink)
gesundheit's Avatar
Member: 17851
Thanks Meter: 151
how do you kick out of recovery if you have 4.2.1?
what tool are we going to use? (i only have tool for 4.1) :sad
Old 12-07-2010, 08:10   #10 (permalink)
Member: 1427645
Sonork: sohail----
Thanks Meter: 27
helloo any bosy help pls i update ipad ver.4.2 after no sound..and same thing iphone4...
pls help me argent,,,thnx
Old 12-07-2010, 08:11   #11 (permalink)
Member: 1427645
Sonork: sohail----
Thanks Meter: 27
update after no sound
Old 12-07-2010, 08:39   #12 (permalink)
Cheater -Don't Deal with him-
Member: 78619
Thanks Meter: 297
Originally Posted by jap_line View Post
very nice trick!
btw,
Br.
this is what is also in my mind..
u will be stuck in a tetherd jalibreak if u will update to 4.2.1..so now a days no need to save baseband all u have to care about is to keep 3gs software version lower than 4.2.1..
Any sugestion for this process will be a great help for all members...
even with 5.15 baseband u have to update base band for unlock to 6.15.
Old 12-07-2010, 11:37   #13 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
shure, i update only to 4.1.
but with this trick you can save you bb.
when i tested other tricks my bb always updatet, but without internet
connection on 2nd check it cant update.
this idea come to my mind when i reded a post here about bb downgrade and
needed certificates wich get downloded later in the update process.
The Following User Says Thank You to oOXTCOo For This Useful Post:
Old 12-07-2010, 12:47   #14 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
Very Good Trick Indeed will test myself, on the weekend. on the 3g,3gs and 4g
Im sure it wont work on 4.2.1 right, due to the firmware checks?
Thank you
Best regard
Old 12-07-2010, 19:06   #15 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
do not test with 3G it will update its baseband, i have tested it.
3G dont recaive certifikate for the bb.
Need 3210 5.31 software without opening phone, can exchange for: igor_m Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-2000 13:38
Nokia 6110 without net. couldnīt call 911 either! DennisT Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-09-2000 11:37
Have seen Nokia 6150's SPUnlocked + IMEI Change without and cables!! KingOfKingston Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-12-2000 12:45
Impossible without TDF-4? BiG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-22-1999 22:32
Page generated in 0.32621 seconds with 9 queries
