Old 11-06-2011, 03:12   #1 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 266
3g holways stuck..recovery mode
Hello y have try update my 3g 8 gb true itunes normaly but holways iam stuck true itunes 1015...
y tchange sistem ...xp.....windos 7 and bouth same error...
y try 4.2.1 try 4.0.....try heven 3.1.3 and holways same error....but at 80% never finish install complete it just restart and give error....wen is connect to usb computer it turn off halone and display black....holways ........y have to turn on and manualy
maybe hardwere problem_______?
Old 11-06-2011, 06:59   #2 (permalink)
tochits's Avatar
Member: 856640
Sonork: 100.1606320
Thanks Meter: 281
try to use redsnow9.9b7
use fix recovery...
or else restore with CFW to bypass the baseband 6.15 that cause error1015..
then jailbreak and unlock your device...
Old 11-06-2011, 11:53   #3 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 266
use fix recovery...
restore with CFW to bypass the baseband 6.15-----»how to do this????i fink problem is realy this...
Old 11-06-2011, 11:59   #4 (permalink)
.::SOLUTION::.'s Avatar
Member: 1653223
Sonork: 100.1619309
Thanks Meter: 146
just restore from itunes and if error then use tinyumbrella and exit the recovery mode.......................All The Best...............
Old 11-06-2011, 12:02   #5 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 266
yes y try that olredy.....it kent finish instalacion it goos maximum to 80 % then error on itunes 1015
and about wed red redsnow y got this error above
Old 11-06-2011, 12:04   #6 (permalink)
Member: 1653223
Sonork: 100.1619309
Thanks Meter: 146
give me your tem viwer id and password
Old 11-06-2011, 12:11   #7 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 266
956 077 839 here´s it is
2683
Old 11-06-2011, 12:16   #8 (permalink)
Member: 1440240
Sonork: JiBriL DcTeAm
Thanks Meter: 116
Downgrade to 4.1 and use tinyUnbrella or recboot to fix recovery mode .
in 4.2 you couldn't fix recovery mode .
go delete apple server adress in host file before retry to restore , for avoid you to get error 34xx or else . you will get error 15xx that is normal .
The Following 2 Users Say Thank You to leonard devinci For This Useful Post:
Old 11-06-2011, 13:29   #9 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 266
problem solve we help of SOLUTION::.'s
many tank´s
Old 11-06-2011, 13:42   #10 (permalink)
Member: 1440240
Thanks Meter: 116
again new experience for you .. good it
The Following User Says Thank You to leonard devinci For This Useful Post:
Old 11-06-2011, 14:21   #11 (permalink)
philzfog16's Avatar
Member: 790617
Thanks Meter: 57
i have same problem on same set will try now and post
Old 11-07-2011, 10:48   #12 (permalink)
Member: 1653223
Sonork: 100.1619309
Thanks Meter: 146
many tank´s
You Are always welcome....................
3210 Vibra-Mode with pclocals mongoq Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-23-2001 15:54
Test mode ericctc Motorola Old Legacy (EMMI) 0 07-24-2000 07:22
Clone mode with PIC16C84 - need work HEX file MP Motorola Old Legacy (EMMI) 5 06-26-2000 12:17
Clone mode on d520 tomi_no Motorola Old Legacy (EMMI) 1 05-23-2000 23:35
Page generated in 0.29470 seconds with 10 queries
