01-28-2010, 18:26 | #1 (permalink) |
Junior Member Join Date: Jan 2004 Location: italy
Member: 50700 Status: Offline Thanks Meter: 12 | 3g no charge no usb solution 2- replace i/o connector flex and pcb connector 3- replace 1 or 2 transistor under shield (check oxy), if no transistor available make jumper. phone charge @ 290mA , stop charge after 5h, dont get hot and stby time is right. probably transistor cut power when too hot or someting like. if solved press thank!! |
The Following 5 Users Say Thank You to pinop For This Useful Post: |
01-28-2010, 19:17 | #2 (permalink) |
Member: 50700 Status: Offline Thanks Meter: 12 | sorry cant upload... http://www.allfreeportal.com/imghost..._no_charge.jpg |
The Following User Says Thank You to pinop For This Useful Post: |
02-11-2011, 18:44 | #6 (permalink) |
No Life Poster Join Date: Feb 2004 Location: GSM-CLINIQUE.COM, SOUTH COAST Age: 43
Member: 54945 Status: Offline Thanks Meter: 22 | just rehot all component near dock connector works 100% FOR OUR SHOPS DONE BY GSM CLINIQUE |
The Following User Says Thank You to TOZE For This Useful Post: |
07-12-2011, 23:04 | #10 (permalink) | ||
Junior Member Join Date: Jul 2011
Member: 1614586 Status: Offline Thanks Meter: 0 | Quote:
in my case there are transistors in the place of the green line's, do i have to break them away? And do you mean by replacing the PCB connector, the connector placed on the mainboard or the connector on the ribbon. Quote:
02-09-2012, 13:20 | #11 (permalink) | |
Junior Member Join Date: Oct 2011 Location: Caloocan, Philippines Age: 37
Member: 1672489 Status: Offline Thanks Meter: 1 | many thanks bro. it helps a lot to me:) Quote:
SE K700-500 no charge-joystick-mic solution here.. | ufuktakiadam | Sony Ericsson Hardware Repair | 0 | 07-08-2009 10:38 |
C65 no charging need real solution | Freshbol | Siemens Hardware Repair Area | 8 | 11-13-2007 14:09 |
W550 no charging, help with solution | idhamitov | Sony Ericsson Hardware Repair | 1 | 10-24-2006 06:41 |
Repairing Jxx: zero IMEI, no charging, no net. | Chuk | Sony | 41 | 08-20-2004 10:06 |
T28s No Charge, No Network, Dark Displey and no Light | Sultan | Sony Ericsson Hardware Repair | 2 | 05-15-2002 00:57 |
