Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products)
iPhone ,iPod & iPad (Apple Inc. Products) iPhone 2G / 3G / 3GS / 4 / 4s / 5 , iPod , iPad / II / New, Apple TV and All Apple Inc. Products goes here
Old 05-22-2012, 13:02   #1 (permalink)
Member: 1759223
3gs 4.1 gsm signal dilemma
See if you ever came across this and share your solution por favor fellas.
IPHONE 3GS 4.1 baseband 6.15, jb and unlocked.
It will get full signal on one carrier SIM card and only 3 Bars on another.
All should have full gsm signal in my location but it is not the case with this iphone. i know it is not hardware issue like antenna as this phone gets full signal with all other carriers around.
I checked Network settings, swapped different sim of the same carrier, nada!
I am not sure what the deal is any tips welcome
The Following User Says Thank You to hbhbhb For This Useful Post:
Old 05-22-2012, 13:10   #2 (permalink)
ribbentrop's Avatar
Member: 40400
Do you know how many bands are used in iPhone ?
Old 05-22-2012, 13:14   #3 (permalink)
Member: 1759223
what do you mean my friend?
if i wasnt clear enough let me repeat that the same sim on another phone in the exact same location gets full signal
The iPhone is a quad band GSM device meaning that it can use all of the GSM frequencies around the world. The frequencies are 800/1900 (US) and 900/1800 (Europe).
Old 05-22-2012, 13:40   #4 (permalink)
ribbentrop's Avatar
Member: 40400
This is hardware problem, sure . Check up Apple hardware section
Old 05-22-2012, 13:47   #5 (permalink)
Member: 1759223
dude, it cant be hardware since this iphone gets full signal with other sims! it is only with this particular carrier that has 3G sims, that the iphone gsm signal drops to 3 bars
Old 05-22-2012, 14:26   #6 (permalink)
ribbentrop's Avatar
Member: 40400
This operator might use another band, open iPhone schematic and you'll see how many ways are used to get signal from antenna . For each band - own way .
Old 05-22-2012, 15:49   #7 (permalink)
Member: 1759223
Thanks man, i will continue and hope to find a tweak or something to get better signal. Good thing 3G is available, and the prob isnt crucial
Old 05-22-2012, 16:07   #8 (permalink)
Member: 1759223
found out that as soon as 3G gets turned off, friggin signal goes up to full bar. WTF
Anybody knows of a tweak to trick this biatch
Old 05-22-2012, 18:29   #9 (permalink)
Member: 1759223
Any guru out there to come up with a fix and have both 3G and full GSM signal.
As soon as I enable 3G , GSM signal loses two bars
disable 3G, then it gets full signal
Old 05-22-2012, 18:38   #10 (permalink)
Brka's Avatar
Member: 163
sounds weird,
but you should try with another identical phone,
on same place, same thing.
p.s. 3G network, operates at hihger band - higher band = lower signal
so, do the testing with another same device, if showing same,
than it's operator low power on 3G network.
p.s.2 i had some strange issues with one 3Gs on 6.15 BB,
worked normal on 3G, but on 2G being unreachable,
customer told me it was working normal before BB 6.15,
so consider that too ...
b.r.
Alex
The Following User Says Thank You to Brka For This Useful Post:
Old 05-22-2012, 18:52   #11 (permalink)
Member: 1759223
Thanks for the info Alex.Most likely it is the provider here. I should be getting some 3g's shortly and will do some testing. My windows phone all are getting full signals with the same sim card.
Old 05-22-2012, 18:55   #12 (permalink)
ribbentrop's Avatar
Member: 40400
It's well known problem with the SKY, try to rehot it .
The Following User Says Thank You to ribbentrop For This Useful Post:
Old 05-22-2012, 19:12   #13 (permalink)
Member: 1759223
YEAH umma try to get a plan out of here in search for a better sky haha
Old 05-22-2012, 22:12   #14 (permalink)
Brka's Avatar
Member: 163
he probably thought about SKYWorks RF ic in the phone ...
correct me if i am wrong
b.r.
Alex
Old 05-23-2012, 04:36   #15 (permalink)
ribbentrop's Avatar
Member: 40400
Yes, of course . You are right
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
DES key Driver black Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 07-19-2012 05:32
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-19-1999 17:41
Page generated in 0.44458 seconds with 12 queries
