Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products)
iPhone ,iPod & iPad (Apple Inc. Products) iPhone 2G / 3G / 3GS / 4 / 4s / 5 , iPod , iPad / II / New, Apple TV and All Apple Inc. Products goes here
Old 05-18-2012, 14:56   #1 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
3GS Always recovery after flash/ireb
Hi to all,
got myself an iphone 3GS on recovery mode, and tried to kick out of this state with firmware umbrella, but greenpois0n payload didnīt do the job. tried as well with ireb and redsn0w, none of them could fix recovery. so, got deviceīs ECID with redsn0w, and looked for its blobs, no shsh were saved on cydia, so decided to flash 4.1 on it.
flashed 4.1 custom deactivated, all went fine, but still, phone got in recovery mode. tried again with redsn0w, then firmwareumbrella, then ireb, but still the same. to make sure phone has a problem, flashed it with stock 5.1.1, no errors, but after is still went to recovery mode.
downgraded it back to 4.1, ran ireb, but still the same. do anyone have any ideas of how I can kick out of recovery?
br
Old 05-18-2012, 15:05   #2 (permalink)
ahsan bhi's Avatar
Member: 605545
if your set is itune after i rib then reflash your phone more 1 time and after use i Rib your problam will b solv 100%
Old 05-18-2012, 15:34   #3 (permalink)
Member: 1198842
Originally Posted by vazgsm View Post
Hi to all,
br
Your auto-boot = False at the env.
use Irecovery with command at Terminal as following
setenv auto-boot true
saveenv
fsboot
do it 5-10 time, to be sure env written to true
then at end write
reboot
your device will reboot hopfully in true mode
Notice, when you start irecovery it will test for you all env check if there are no panic. as it is no panic cause you can restore with itunes.
The Following User Says Thank You to frake50 For This Useful Post:
Old 05-18-2012, 16:10   #4 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
@frake50
great idea! but do irecovery connects with 3gs new bootrom? I though it was only for 3g/2g, used it some times long time ago... anyway, Iīll set up lib2usb in a xp laptop to try it out. thank you for your thought.
Old 05-18-2012, 21:22   #5 (permalink)
Member: 1198842
@frake50
Its work either on Iphone 4 to set env.
Old 05-23-2012, 20:39   #6 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
it kind of worked... after irecovery it stopped booting into recovery, but does not complete boot also. it hangs on the apple, with "loading" animation, and then restart, like a tethered boot.
Old 05-23-2012, 21:19   #7 (permalink)
Member: 735092
if you tried all the software solotion and its not fix try to power the phone with out tha cable of speaker try it and post result
The Following User Says Thank You to yehndrahcir For This Useful Post:
Old 05-23-2012, 22:31   #8 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
[ Problem Solved! ]
with dock ribbon disconnected, problem remained. but when I powered it on with just a test lcd (without lcd,frame,touch etc), it got up! now I know itīs a weird problem with lcd or digitizer, gonna test them, but phone is working.
@ yehndrahcir
itīs funny how things that apparently have nothing to do with the situation may be the cause.. thank you very much for bringing such tip up!
Old 05-24-2012, 09:16   #9 (permalink)
Member: 1499154
i had the same problem!
The problem is the home button is stuck and the phone always starts in recovery! check the home button, home button flex, charging flex!
FLASH BOX WANTED!!!!!! J Wanted Products 9 07-14-2012 20:42
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 03-07-2000 21:24
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 0.28824 seconds with 11 queries
