| Apple Inc. Products iPhone 2G , iPhone 3G , iPhone 3GS, iPhone 4 , iPhone 4s , iPod , iPad , Apple TV |
| | #1 (permalink) |
| Moderator ![]() Join Date: Nov 2002 Location: Twitter.com/y0ush4 Age: 31
Member: 17689 Status: Offline Sonork: 100.72392 Thanks: 29
| 3GS Always in Recovery mode after Reboot its a NEW IBOOT VERSION when you run blackra1n on it it will make the handset JAILBROKEN but (tethered jailbreak) Now the question is What is this Fcuking TETHERED JAILBREAK? Simple Answer :TETHERED JAILBREAK is you need computer everytime when you need to reboot your phone and run blackrain everytime to reboot it properly and moreover its not a BUG in blackra1n it FEATURE this problem occures mostly on the OTB 3.2.1 Read the MASTERS BLOG AGAIN and use your MIND ![]() http://iphonejtag.blogspot.com/ if your ipt2/3GS/ipt3 is rebooting into recovery after running blackra1n, this isn't a bug. It's a feature. You need to run blackra1n every time to boot it. This 'feature', called tethered jailbreak, is enabled by upgrades Apple made to the bootrom and the fact ipt3 uses nand flash. |
| | #2 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2004 Location: Mobile phone world
Member: 90701 Status: Offline Thanks: 400
| iPhone 3gs goes recovery mode while trying to restore comstom file Quote:
| | #3 (permalink) |
| First clear it which phone you are using if its IPHONE3G-S than the above stated problem have no solution till yet if you have IPHONE2G OR 3G than you can try to recover it from I-RECOVERY CONSOLE http://www.mediafire.com/file/ywhxqz...%20&%20Mac.rar WIN-XP 1=INSTALL libusb-win32-filter-bin-0.1.12.2.exe 2=START-->RUN-->iRecovery.exe -s(with proper path and handset should be in recovery mode) 3=type these commands as it is setenv auto-boot true saveenv reboot or fsboot (one of them) |
| The Following 13 Users Say Thank You to yousha For This Useful Post: |
| | #4 (permalink) | |
| | #5 (permalink) |
| in iRecovery, type printenv Copy the result and Post here or Alternativly you can yourself see the AUTO-BOOT flag is set to TRUE or FALSE .If it is set to "false" that needs to be changed to "true" (auto-boot="true"). Do this by typing: setenv auto-boot true (but i highly doubt its the case with 3G-S) let me know the result i am here |
| | #6 (permalink) | |
| | #7 (permalink) |
| My problem for now is i am not having the similar problem handset in hand otherwise i would be testing tons of things over it i have in my mind right now if anyone having the similar problem in IPHONE3G-S only can contact me on MSN or Whatever messenger probably we could fix it wbr y0 |
| | #11 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2006 Location: Addis Ababa
Member: 279453 Status: Offline Thanks: 51
| Check the serial # of the phone under Settings | General | About. If the 4th and 5th digit of the serial is "40" or higher, then you got a phone with the new iBoot and will require this each time its rebooted, unless/until someone comes up with a way to hack this in the future. And this applies if you use BR1 or PwnageTool/custom IPSW to JB. No tools exist currently to get around this. |
| | #15 (permalink) | |
| Quote:
| The Following 5 Users Say Thank You to yousha For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Without problem "ALWAYZ recovery mode after reboot with Blackra1n" | anpha72000 | Apple Inc. Products | 1 | 01-27-2010 09:16 |
| Recovery mode after reboot | coeugh | Apple Inc. Products | 5 | 01-07-2010 00:03 |
| 3GS stuck in recovery mode after power on | leebok | Apple Inc. Products | 7 | 12-06-2009 16:12 |
| After jailbreakin iphone 3GS still in recovery mode | xpcenter | Apple Inc. Products | 2 | 11-11-2009 05:50 |
